Help with 4l60e
Old Nov 18, 2011 | 02:24 PM
shix's Avatar
Default Help with 4l60e
I just finished up a v6 to v8 swap in a 96 Camaro. All drive train parts are out of my old 94 z28 as well as harness and computer. The problem i am experiencing is when the car goes to shift into 3rd it feels as if it goes into neutral until the rpms rise a bit then it feels like it is just working very hard to slowly accelerate. if i put the car in drive or 3rd it will shift fine until 3rd gear then it will not shift at all until the car is almost completely stopped. So it wont shift back down into 2nd or 1st until the car near a stop or until i manually select either 1 or 2. The trans has maybe 5000 miles on it since the rebuild and hasn't really been abused. The only thing changed about it is a tune for shift points done by Solomon of LT1pcmtuning.com and i used Amsoil torque drive synthetic ATF. I posted this in the trans section as well. Just trying to get a speedy answer because i need my car to get back to school monday.
Old Nov 18, 2011 | 02:32 PM
RamAir95TA's Avatar
Maybe check your TPS voltage at part throttle. Funky TPS voltages can cause shift problems.
Old Nov 20, 2011 | 11:15 AM
shix's Avatar
tps voltage checked out good.
Old Nov 20, 2011 | 12:48 PM
djjab57's Avatar
Maybe check the force motor,
Old Nov 20, 2011 | 12:52 PM
lt1slowz28's Avatar
5 bucks says it's the tune or VSS... try to get a stock one on it... if it doesnt cure the problem it is likely an internal trans issue
Old Nov 20, 2011 | 12:59 PM
djjab57's Avatar
Try manually shifting from 1st and move up as you drive , Tell me how it works that way. If it works good It will be the Force motor
Old Nov 20, 2011 | 01:40 PM
shix's Avatar
manually shifting it has the same result.
Old Nov 20, 2011 | 02:19 PM
Badazz 97 TA's Avatar
fluid level? not enough or too much
Old Nov 20, 2011 | 04:28 PM
shix's Avatar
on the stick its a very tiny bit above hot when at operating temp
Old Nov 20, 2011 | 09:37 PM
jaycenk's Avatar
Did it work right before the swap? Might try throwing a scanner on it that can pull trans codes. Not all scanners can do it. You might get lucky and have something show up.
Old Nov 22, 2011 | 07:49 PM
shix's Avatar
well i found out my dad took it out 2 weeks ago while i was at school with low fluid and it started slipping on him. Pretty sure its toast
Old Nov 22, 2011 | 07:52 PM
lt1slowz28's Avatar
there you have it... maybe now you and your dad can go 50/50 on a built trans?
Old Nov 22, 2011 | 08:14 PM
RamAir95TA's Avatar
If my dad drove MY car with low/no transmission fluid there's no way that'd be a 50/50 deal.
Old Nov 22, 2011 | 08:25 PM
lt1slowz28's Avatar
true, I was just trying to be nice... avoid confrontation as you would.
Old Nov 23, 2011 | 10:38 AM
shix's Avatar
he said he is gonna try to take care of it for me. He has a possible 6 speed lined up for it im not gonna let him foot the bill on his own. He has helped me out so much with the car.
Old Dec 22, 2011 | 06:29 PM
bizerk1's Avatar
I have one for sale cheap that works, 4l60 that is. 300$
Old Dec 23, 2011 | 04:39 PM
bowtienut's Avatar
If you're going to rebuild it, up the road from you in Dayton is a guy who builds the best 4L60E's for miles around.
Mike Harris at B-Body Performance. 1FAST94 on here.
I have his 4L60E's in my car and truck and they take a beating with no issues.
