fuel injectors
Old Nov 18, 2011 | 05:34 PM
casey20000007's Avatar
Question fuel injectors
i have a 383 lt1 with stock fuel injectors that are going out what injectors would be bertter? SVO red top 32# or bosch III 42#
i have a walboro fuel pump with factory reg. i plan on putting a bigger tb on and intake on in the future and some aftermarket heads..
there has prob already been someone asking this but i dont have tim to do in depth research
Old Nov 18, 2011 | 07:36 PM
defaultexistence's Avatar
36 or 42's I cant believe your getting away with stockers And not leaning out...what is your combo from heads to pan?
Old Nov 18, 2011 | 07:40 PM
lt1slowz28's Avatar
bosch 3 42's will be a good start and have room to grow.
Old Nov 18, 2011 | 07:43 PM
Houdini's Avatar
42's from RaceTronix... Its what I run on my H/C/I LT4 and tunning was nice, no issues.
401 rwhp 375 rwtq
I imagine your 383 would move more air than my engine.
Old Nov 19, 2011 | 09:05 AM
i have stock heads with a lil port job with 1.7 rocker studs and liberty roller rockers with liberty doube behive spring msd opti, srp pistons with 60cc dish, stock connecting rods, erson costom cam 548 lift 108 lsa, scat crank, and bigger/better oil pump not sure what kind off the top of my head... and i had my computer tuned by PCM forless
Old Nov 19, 2011 | 09:13 AM
which injectors would be the easiest to tune? bosch III 42#'s or racetronix 42#'s
Old Nov 19, 2011 | 09:36 AM
What was your AFR's and power on stock injectors and tune? 60cc dish pistons?? What was CR?
Old Nov 19, 2011 | 11:21 AM
lt1slowz28's Avatar
I personally like the boschIII, best spray pattern I have seen yet for a n/a app.
Old Nov 21, 2011 | 08:24 AM
whats AFR's sorry lol? not sure bout how much hp and whatnot with stock injectors and tune i never got a chance to dyno.... and yes 60cc is what i was told when i ordered them... and my cr is 11.5:1 it was 10.5:1 from factory i think..
are these the right ones your talking about? Bosch 0280155968 Fuel Injectors
i also found some on fuelinjectorconnection.com
they are the bosch BLUE DEMON 3 modified
which ones would be the easiest? no fitment prob. or connector issues?
Old Dec 2, 2011 | 12:45 PM
ok i got my injectors in yesterday and i'm hoping to put them in today if the wether permits, its sposed to snow/rain later on today and tomorrow... i got the bosch 3 #42's
oh and does anyone know how to relieve the fuel pressure without disconnecting the fuel lines?
Old Dec 2, 2011 | 12:50 PM
lt1slowz28's Avatar
before you put in the injectors... please get a tune... you will flood your motor with fuel and end up doing some bad things.
Old Dec 2, 2011 | 04:03 PM
RamAir95TA's Avatar
I also suggest slowing down. Judging by the parts used in your build you have a lot to learn.
You can't just swap in larger injectors - you need a tune or as mentioned above you'll dump tremendous amounts of fuel into the cylinders, likely washing out the rings and doing other very bad things.
Old Dec 3, 2011 | 07:56 AM
i already have a tune on the ecm i nust need to get an update for the injectors pcm for less said its $50 for an update plus shipping
and i put them in last night and started her up and i got a leak on #6 and #8 i didnt let her run for more than 5 sec
Old Dec 3, 2011 | 08:32 AM
lt1slowz28's Avatar
im trying to help you dude... but you keep doing the wrong things.
Old Dec 3, 2011 | 09:19 AM
i didnt get on till this morn so i didnt see you guys's warning but i wont start it no more till the update on my ecm and i appreciate the help from all of you guys
Old Dec 3, 2011 | 09:27 AM
Rob94hawk's Avatar
I have Lucas 42# injectors and Walbro pump w/ harness. Yanked the PCM and got a tune before I started it up. Got my stuff from
http://www.lonniesperformance.com/
If you're getting a 58mm TB then make sure you have your intake ported to match it.
Old Dec 3, 2011 | 09:51 AM
thanks for the heads up man i woulda never thought of doin that with the intake and i prob woulda messed somthing up oh and which tb should i get? holly, summit, edelbrock ect. ? and to get the intake off dont you have to take the valve covers off?
Old Dec 3, 2011 | 10:22 AM
Rob94hawk's Avatar
My favorite is the TPIS 58mm TB.
http://tpis.com/parts/view/49
I have a used BBK 58mm from Jason Short but as soon as Xmas is over I'm going TPIS. But if you're on a budget search the for sale sections in here and camaroz28.com. Someone is always selling a 58mm TB.
For now put your $$ into your heads and intake. This is where you'll make most of your power.
Old Dec 5, 2011 | 12:23 PM
ok i shipped my my pcm this morn should get it back by thurs or fri i hope
Old Dec 5, 2011 | 12:34 PM
GIZMO's Avatar
If it performs well with stock 24 lb injectors you don't need anything larger.
