head gasket questions
Old Nov 30, 2011 | 11:13 PM
  #41
FocusVince's Avatar
****...sorry its showing up on my computer so I guess something is wrong...I'll try again.
Old Nov 30, 2011 | 11:26 PM
  #42
FocusVince's Avatar
did that work?
Old Nov 30, 2011 | 11:35 PM
  #43
defaultexistence's Avatar
Yeah.. But number them according to cylinder ... And where's the rest?
Old Nov 30, 2011 | 11:39 PM
  #44
FocusVince's Avatar
I had to leave for work so I could only get 3 at the time. Those are cylinders 1,2, and 3...
Old Nov 30, 2011 | 11:47 PM
  #45
the_merv's Avatar
Veteran: Air Force
Look lean to me..ideal running engine should look like buttersctoch.
Old Dec 1, 2011 | 09:05 AM
  #46
FocusVince's Avatar
Oh and something else I noticed....there is a whistling kind of sound coming from the brake booster area, I forgot to mention that...could that be causing my problem??? I can't believe I forgot to mention that..
Old Dec 1, 2011 | 12:06 PM
  #47
the_merv's Avatar
Veteran: Air Force
Sounds like the Booster is leaking..they get moisture in them and rust out..
Old Dec 1, 2011 | 01:15 PM
  #48
FocusVince's Avatar
Could that be causing my problems?
Old Dec 1, 2011 | 01:23 PM
  #49
What do you think man...? Does vac leaks cause issues??
Old Dec 1, 2011 | 02:11 PM
  #50
FocusVince's Avatar
Ugh well of course it causes issues but I meant would it really cause my car to run and have ALL of those issues I noted in the first post? WOuld it really foul my plugs like in the above pic? Would it really cause white smoke?? That is what I meant.
Old Dec 1, 2011 | 02:55 PM
  #51
FocusVince's Avatar
And simply put I'm stumped on what to do right now. I didn't want to just start throwing parts at it..but it seems like its come to that.
Old Dec 1, 2011 | 06:45 PM
  #52
FocusVince's Avatar
So the symptoms I'm experiencing are:
Light white smoke coming from exhaust.
The engine is down on a lot of power.
Whistling sound from brake booster area.
White residue of some sort on spark plugs.
Runs extremely rough.
I'm thinking either:
A. Blown head gasket
B. Monster vacuum leak
C. Bad motor mounts (doubtful)
D. Something else.
I am absolutely lost on what could be wrong, whethher its one thing, or if its a combination of a bunch of things. What do you guys suggest I do? Should I just replace the head gaskets and see what happens? There looks like a small ammount of cross contamination in the coolant, but the oil is still black (it needs to be changed though).
Old Dec 1, 2011 | 07:05 PM
  #53
Yes, vac leaks will cause rough running conditions, are you sure the damn smoke isnt just condensation in the exaust trying to steam out? Fix the vac whistle!! 1st!!
Old Dec 1, 2011 | 09:54 PM
  #54
FocusVince's Avatar
I'm not trying to **** you off I'm trying to list all my problems and what's going on, and condensation after running for 15 minutes? Seems a little long to me.
Old Dec 1, 2011 | 10:07 PM
  #55
IronOutlaw's Avatar
Fix the vacuum leak and go from there. I doubt you blew a headgasket without running it really really hot.
Also my plugs have looked like that after using injector cleaner in my ranger. Have you used some sort of cleaner recently?
Old Dec 1, 2011 | 10:12 PM
  #56
Not pissed lol , I kina enjoy this.. just trying to get the point across and jump start the engine you lol
Old Dec 1, 2011 | 10:21 PM
  #57
FocusVince's Avatar
No cleaner recently. I'll check for the vacuum leak I looked over it a little today and the brake booster line looks okay I'll check more tomorrow...maybe my brake booster is bad. I am starting to doubt that I blew a head gasket now...
Old Dec 2, 2011 | 01:50 PM
  #58
FocusVince's Avatar
Also going to try converting to heated o2 sensors soon...maybe that is another problem I'm having, it ran good for awhile but its gotten a bit colder out now so maybe that has something to do with it...idk. just throwing it out there
