Lethal birds 24x thread
Old Dec 28, 2011 | 08:20 PM
  #101
lethal bird's Avatar
And a huge thanks to Mike for clearing that up because it would driving me nuts for weeks. Well guys I think I'm about done with my harness now to clean it up.
Old Dec 28, 2011 | 11:21 PM
  #102
SoxXpupPeT's Avatar
sweet! think youll have her fired up before the new year?
Old Dec 28, 2011 | 11:47 PM
  #103
Nope still need a knock sensor, PCM, and a mail order tune.
Old Dec 29, 2011 | 01:52 AM
  #104
This is the correct pcm right?
http://www.ebay.com/itm/Trans-Am-200...ht_1165wt_1341
Old Dec 29, 2011 | 09:03 AM
  #105
SoxXpupPeT's Avatar
Yup thats the proper ECU code '411' get a knock sensor from your localparts store or rock auto. i got it for around $40 iirc. i emailed speedinc about a mail order tune but i havent gotten anything back from them yet...
Old Dec 29, 2011 | 01:14 PM
  #106
95mysticta's Avatar
There was a guy selling three 411's on camaroz28 at 50 bucks a pop if there still around. Im still trying to find a cheap used knock sensor myself to keep costs down.
Old Dec 29, 2011 | 09:05 PM
  #107
So did we ever figure out if we need ac evap and outfield service.
Old Dec 29, 2011 | 11:49 PM
  #108
I didn't see them in the ls1 PCM. Cross your fingers for me.
All the unneeded junk.
Old Dec 30, 2011 | 02:26 AM
  #109
lymlyt96's Avatar
Hey lethal if you get this thing runnin on the first try do you think you could do a writeup on the whole harness conversion? I have the kit already I'm just waiting to get a baseline dyno run to see if there's a difference before and after the swap.
Old Dec 30, 2011 | 04:14 AM
  #110
S10Wildside's Avatar
Both LT1 and LS1 PCM control the A/C compressor clutch through a relay. The A/C wiring is identical between LT1 and LS1 cars...with the exception of the LT1 A/C Evaporator Temperature Sensor. That sensor is a signal used with the LT1 PCM but not with the LS1 PCM. The wiring for that sensor goes away with an LS1 PCM conversion.
Old Dec 30, 2011 | 07:59 AM
  #111
95mysticta's Avatar
Im sure there is going to be a few of us shortly putting together a fully detailed sticky thread of there harness builds. I just dug into mine last night and its going slow but making sure everything is documented, labeled, and checked off on the list im making as i go through it. Its really intimidating but if you take your time its really not to bad.
Old Dec 30, 2011 | 09:15 AM
  #112
Sc0tt30's Avatar
Glad to see you got it all done.
Old Dec 30, 2011 | 09:37 AM
  #113
355z28's Avatar
Thanks for this information Mike, what about the UART serial data, is that needed? Im a little confused with it since the lt1 has one wire for it and the ls1 pcm has cavities for it.
Ive found most people have powered their coils from the fuel injectors, would it be bad if I ran them off a single relay triggered by ign power?
Old Dec 30, 2011 | 10:16 AM
  #114
That's really a question for GM engineering. So the way I look at it is that the UART signals on the LS1 PCM (BLUE 14 and BLUE 15) are only (??) used with systems that have a throttle actuator control module (Corvette and few trucks). I have no reason to assume that the LT1 signal is related to the LS1 signal.
About the fuel injectors
In 1993 they were powered by two separate fuses; one for each bank.
In 1994-1995 they were powered by two separate fuses; 2,3,5,8 and 1,2,6,7.
In 1996-1997 they were all powered by one fuse.
Why not use the ignition coil/ignition module power wire? (Depending on the year you are working with) it's the highest rated fused ignition source with the largest size wire (18ga)...and (again depending on year) is not used to power anything else.
Old Dec 30, 2011 | 11:14 AM
  #115
355z28's Avatar
I can't believe I overlooked that on my 96. Thanks again Mike! My brain is fried a little after comparing schematics for the last couple days. I really appreciate all the help you have given. Great Customer support with a great product.
Old Dec 30, 2011 | 12:58 PM
  #116
Once again huge thank to mike for getting this cleared up for us. Now I feel a little more comfortable with the harness now. When I'm finished and it's back in the car I'll do my best at trying to get thread to help all the people in the future.
Quick question how do I wore in the obd port.
Old Jan 1, 2012 | 01:41 AM
  #117
SoxXpupPeT's Avatar
Go get it lethal! Its looking great so far from the pics! Mike sent me an email today telling me my harness is ready ! to bad my car isnt anywhere near ready for it
Old Jan 1, 2012 | 08:33 AM
  #118
xtreme2001's Avatar
are ya having fun lethal?this is where i am glad i have gm service manuals handy....i'm glad you tried tackling this yourself.......but like i said.........i would have done it for you......wally
now to get me some new correct length pushrods and fix this lt1 383 so the wife can drive her car
Old Jan 1, 2012 | 01:28 PM
  #119
Yea I was going to let you do it but the more I looked at it the easier it looked. The only problems I had were wether or not I needed a few wires. It took all of about 5-6 hours but it done other than taping it up.
Old Jan 2, 2012 | 04:29 AM
  #120
OBDII Diagnostic Connector Cavity Assignments:
2 - Class 2 Serial Data (PCM BLUE 58 and BLUE 59...they are the same...most use BLUE 58)
4 - Ground
5 - Ground
16 - 12V Battery
