what are you nitrous guys picking up in mph?
Its been brought to my attention that my car doesnt pick up as much mph as it should on gas. On a 150 shot (it doesnt get the whole 150 its more like 125 to the tire) it only picks up 6mph in the 1/8th and picks up 9mph in the 1/4 over my na mphs. Is this low normal or about right?
Combo is :stock bottom end and heads. comp cams 224/236 on a 114 cam and supporting mods. vig ''2800'' stall, 3.42 gears, and just about all the bolt ons i can think of to go on the car.
Also weighed the car it weighs 3570 with me in it. I know with a jockey it'd go faster.
Yes the cars been tuned. Did not think about it blowing through. The converter is pretty loose. It was suppose to be a 2800 vig but its more closer to 3200
Good lord
Depending on whether a car is stock heads/cam or a good breathing topend, I see from 10 to 13 mph in the 1/4 mile on a 150 shot with the heavier B-bodies. You should see slightly more with a 3500 lb F-body.
Do you think the 3.42 gears would be hurting it that bad? Its had a different converter in it and it still did the same. Its still a street car so I dont wanna move the stall up any further than it is now.
My friends who had similarly modded cars said I should be picking up about 10mph. And though 96mph in the 1/8 was pretty low
IrocZ,
Your 3.42 gears aren't hurting you on the spray much at all.
Is that 2800 Vig a 9.5" or a 12"? If it's a 12" (I think they make an economy model like that?), get rid of it. The higher-stalled 12" converters are very inefficient when you try to put a bunch of torque through them.
IrocZ,
Ok good, I do like the 3.42's on the highway.
No its the 9.5''. I asked for 2800 and this has been a while ago. And its more like 3400 or so. The car runs pretty good on motor for whats done to it.
Also it dyno'd 315rwhp with the converter unlocked on motor and 440rwhp with the converter unlocked on gas. On a 150 shot. The 489 number in my sig is with the converter locked up.
Hmmm.....49 hp locked vs unlocked is worrisome to me, especially if it was supposed to be 2800 stall.
If it's flashing to 3400 on the 150 shot that's ok, but if it's doing it on motor something is wrong with it. ....are you sure you don't have a tranny going south?
Like I said it was supposed to be a 2800 I dont think thats what they gave me. I havent looked in a lil while but i remember it flashing higher on the gas. But thats just going off my digital window switch. If its been going out its been going out for a very very long time. Its run this from day one. And I think maybe with another trans and stall in it. I'll have to go back and do some digging on when I got the new trans and stall but its been at least 4 years.
