Spray vs Compression
Old Dec 21, 2011 | 08:25 AM
jayz28's Avatar
Default Spray vs Compression
I'm starting to think being really fast takes nitrous or boost. I can't afford boost, so how about nitrous?
I've got about 12:1 compression maybe more. Forged everything. Could I run nitrous? How much? What kind?
Don't say search!!! LOL Search sux from my crappy cellphone.
Old Dec 21, 2011 | 08:28 AM
alan2000T/A's Avatar
some motor builders i trust say nitrous likes compression. There's no correlation to the need for low compression such as in turbo or supercharger.
Old Dec 21, 2011 | 08:35 AM
quik95lt1's Avatar
Bull$hit!!!
next to that it depends on your bottom end mainly....crank? rods? rod bolts? pistons? ring gap? piston to wall clearance?
all must be factored in......
Old Dec 21, 2011 | 09:02 AM
jayz28's Avatar
Well I'm talking about goin from high 10s to high 9s. Seems like N/A doesn't cut it. There are a few out there though running consistent mid 10s high 9s.
I just don't have the money to do it N/A. So I'm thinking about juice.
Old Dec 21, 2011 | 09:22 AM
gregrob's Avatar
Everything quik95 said plus what is your quench distance?
Its totally dependant on your setup as to how much you can spray.
My setup is 13.6 : 1 and I'm going to spray a big shot, but everything in the engine is setup for it.
Take a Max effort N/A mill and you could destroy it with a 100 shot and the wrong tune up...
Old Dec 21, 2011 | 09:24 AM
bowtienut's Avatar
High 9's with nitrous with a 12:1 forged motor in an F-body should be a walk in the park. That CR is not a hindrance whatsoever. It just means you can light the fire later in the compression stroke.
With the small shot it takes to do that, all you need to be sure of is the quality of the motor build and the top ring gap.
It's so easy, it's CHEATING! ....right, Mikey?
Old Dec 21, 2011 | 10:07 AM
gregrob's Avatar
You also need to be sure of the tune as well. If he has a super tight quench it will make the tuning window pretty narrow.
Old Dec 21, 2011 | 10:47 AM
PWR SHFT's Avatar
If you want to go bigger than approx a 150 shot, you will want to pull the pistons and open up that top ring gap. You set up the ring gaps right, you will be able to spray a ton. Smarter folks on here can tell what the ring gaps should be.
Good luck!!
Old Dec 21, 2011 | 11:15 AM
jayz28's Avatar
Not sure on the quench exactly. But its a quality na build.
Forged 383
AI TFS 215s
24x/24x HR
I was simply wondering if I could run a 100 shot.
Old Dec 21, 2011 | 12:06 PM
69gto96z's Avatar
I ran a 150 shot all day long on a stock bottom end. It should take a 100 shot without problems.
Old Dec 21, 2011 | 12:09 PM
jayz28's Avatar
Fine, ill go with 150 shot then
Old Dec 21, 2011 | 01:42 PM
Uwilllosetomy93lt1's Avatar
Your forge pistons will def help with the increased cylinder pressure yer gonna add. Should hold up with the temps but, setting up the rings on yer slugs r key for heavy hits. You'll do just fine with 100 shot easily, or even 150. Tune her and let her fly...
Old Dec 21, 2011 | 01:45 PM
Oh......ya might want to consider the purchase of another bottle. Good to have another full one ready to go at any given notice.
Old Dec 21, 2011 | 01:58 PM
jayz28's Avatar
What kits do you guys recommend? I have a ported single plane ready and waiting to go on. I thought about going that route with a plate kit.
Old Dec 21, 2011 | 02:34 PM
Wicked94Z's Avatar
for a 150 shot? just plumb a 1/16 nozzle, no need to spend a buttload
Old Dec 21, 2011 | 02:36 PM
quik95lt1's Avatar
yea what he said^
Old Dec 21, 2011 | 02:49 PM
gregrob's Avatar
150 shouldn't be a big deal if you watch the tune up. Start conservative and READ YOUR PLUGS.
Old Dec 21, 2011 | 03:05 PM
Nic Morales's Avatar
I water/methanol kit is a good way to insure safety when spraying also. !
Old Dec 21, 2011 | 03:49 PM
Ballinonabudget's Avatar
I have only ever owned a NX kit, but it was great quality and I never had issues with it. Your goal should be a walk in the park with a little spray
Old Dec 21, 2011 | 05:22 PM
zraffz's Avatar
