LT1 PCM and HEI distributor
Old Dec 27, 2011 | 08:46 PM
913MOTOR's Avatar
Default LT1 PCM and HEI distributor
I have searched but didnt find much, I want to keep the PCM/EFI but want to use a regular hei dist for reliability. My reason is I don't trust a opti on an airboat in a very wet enviroment.
Anyone have any threads or websites with swaps and info?
Old Dec 27, 2011 | 09:06 PM
AR15 guy's Avatar
Are you wanting to maintain the fuel injection?
Old Dec 27, 2011 | 09:13 PM
913MOTOR's Avatar
Yes I want to keep the EFI for fuel efficiancy but not have the fragile opti to worry about.
Old Dec 28, 2011 | 08:53 AM
warriorcustoms's Avatar
Do the 24x to ditch the opti on an LT1 that seams to be the best route
Old Dec 28, 2011 | 09:32 PM
913MOTOR's Avatar
Dont wanna spend all that money on the motor, im not trying to get every hp it. All I want is a more reliable ignition system.
Old Dec 28, 2011 | 09:45 PM
StraightTimeStirrups's Avatar
What is the 24X?
Old Dec 29, 2011 | 08:42 AM
94Z/28M6's Avatar
Here you go , http://www.eficonnection.com/eficonnection/24x.aspx
Old Dec 29, 2011 | 10:41 AM
96TransAmboosted's Avatar
Over on the Vette forums a guy had his intake modded to take a HEIGHT dizzy. Not sure how to copy and paste on my phone. Google hei lt1 and click on pictures its the blue intake. Should take you to hos build thread.
Old Dec 29, 2011 | 11:42 AM
1963SS's Avatar
Are you talking kinda like this. It's not very hard to do once you've seen it. Just use some creativity. This is a HEI distributor with the Opti wheel. You don't need a crank sensor or anything. It would probably be wise to use this with the Bailey LTCC system and the 8 coil packs. I'm not sure that I'd want 40,000 volts jumping around inside the device that uses the 5 volt PCM power......but that's just me. Others have used the regular old cap, rotor and wires with no problems.....I hear. I can't understand it but I do hear.
