Planning for the next LTX shootout. What's with the LS1 PCM weight penalty?
Old 01-01-2012 | 08:28 PM
Rob94hawk's Avatar
Default Planning for the next LTX shootout. What's with the LS1 PCM weight penalty?
1. I keep hearing from so many that the LSX PCM gets you no gains. If so then what's with the weight penalty of +100lbs?
2. Do I qualify for LTX Extreme Street? Thanx
LTX Extreme Street N/A
• Limited to quickest 32 qualifiers
• Sponsor: TBD
• Payout: TBD
Must have LT1-based engine. No power adders permitted. Heads must retain the factory 23 deg valve angle. Trick Flow 21 deg. heads permitted (PN TFS-30400008-M54). Only stock/stock ported intakes will be allowed. Welded intakes not permitted. LS1 PCM permitted with 100 lb. penalty. All other aftermarket EFI systems are prohibited. DOT approved tires only (includes DOT approved bias-ply tires). Radials must retain one of the following aspect ratios (275/50-15, 275/60-15, 255/50-16, 275/40-17, 315/35-17, 295/45-17, 325/45R17). 28″ maximum height and 10″ maximum tread width for bias-ply tires. Must have stock-style suspension. 4-links and ladder bars not permitted. Mini-tubs not permitted. No solid motor mounts, motor plates or anti-roll bars (aftermarket sway bars with solid end-links permitted). Must retain full OEM interior including both front seats. Aftermarket front seats permitted. Rear seats may be removed. Must have mufflers. Must retain OEM type transmissions of one of the following (700R4, 4L60, 4L60E, 4L80E, T56). No trans-brake or two-steps. Must have factory glass. Lexan windows not permitted. Must have working lights, wipers, horn. Must have current tags. Minimum race-weight limit 3,400 lbs. Independent rear suspension receives 200 lb. weight break. Car and driver must meet NHRA certifications for the time the car is running.
Old 01-01-2012 | 09:11 PM
96LT1355Z28's Avatar
It doesn't give you a direct gain if that's all you change but it removes the rpm limit allowing you to spin the engine higher thus the potential to make more power. Looks like you'd fit in Ex Street N/A.
Old 01-01-2012 | 09:59 PM
Puck's Avatar
411 PCM setup would be a huge advantage since you won't be as RPM limited in your cam choice anymore.
A solid roller setup with a 255+ int cam for an 8,000 rpm 383 has the engine potential to totally destroy a smaller cammed 7,000 rpm street/strip car, and it wouldn't really be fair to have in the same class without some sort of penalty.
You should fit into ES N/A.
Old 01-01-2012 | 10:07 PM
Rob94hawk's Avatar
Much appreciated guys. Thanx
Old 01-01-2012 | 10:17 PM
speed_demon24's Avatar
If you're running an 8000 rpm 383 100lbs should have no effect on you destroying a street/strip car.
Old 01-01-2012 | 10:29 PM
joelster's Avatar
All of the rules for next year are being discussed on ltxtech.com . I know that in mod n/a they are trying to remove the weight penalty for aftermarket pcm controllers. Spinning the motor higher allows you to gear it more aggressively which is a big benefit, but you have to build the entire car around it.
Old 01-02-2012 | 11:33 AM
Puck's Avatar
In a lot of situations the LS1 setup is a clear benefit and in a more street oriented class like ES there should be adjustments made for that to keep it form being a necessary mod to compete.
It stinks for the people who don't "need" the setup, and only went with it for reliability and tuning, but something had to be done either way.
I don't think it should have a penalty in MOD N/A, which are naturally more aggressive builds, but for a supposed "street" class builds have to be kept in check.
Old 01-02-2012 | 11:54 AM
355z28's Avatar
Im not too worried about the weight penalty. My car is far from the 3400lb weight limit as it is. Ive gone to the kit for reliability and to fix some upper rpm breakup that I have had for the last few years.
You qualify for the Extreme street. Hopefully Ill make it there to run both power adder and NA this year.
Old 01-02-2012 | 12:50 PM
Valkyn's Avatar
Abit off topic but what is the benefit of running the 58x system that EFI connections also offers? Is it basically the same thing as the 24x?
Old 01-02-2012 | 01:02 PM
BOLO's Avatar
I'm in the same boat here and will hopefully run in the same class if I ever make it.
Old 01-03-2012 | 11:40 AM
sweetbmxrider's Avatar
Those rules are so contradicting. Are they trying to allow certain people to race?
Old 01-03-2012 | 01:02 PM
quik95lt1's Avatar
what they said........in reality i could do this......still spin my rpm....add a 200lb weight bar and make weight for ES N/A and prob run 10.2-10.3's.........thats why lol
Old 01-03-2012 | 01:18 PM
What rule is contradicting?
EX Street N/A: LS pcm permitted w/ 100lb penalty
Mod N/A: same as Ex street but working on no penalty for LS pcm due the the more agressive builds
Old 01-03-2012 | 01:31 PM
05HD's Avatar
Wouldn't it be simpler to limit ES to hydraulic cams and who cares what computer?
Also, they need to add ZF S6-40 transmission for the Corvette.
Old 01-03-2012 | 02:05 PM
quik95lt1's Avatar
because you can rev an agressive HR 7500rpm and make power.........thusly........i say keep the rule
Old 01-03-2012 | 02:19 PM
05HD's Avatar
I think that is a lot closer to what the "spirit" of the rule is than somebody showing up with a 10k rpm solid roller and a slowed down clock speed stock ecu.
BTW, you'd have to swap on a stock intake manifold too.
Old 01-03-2012 | 05:28 PM
Longbob's Avatar
I am not sure if this helps, but the weight penalty for a LS1 vs. LT1 in Stock Eliminator is approximately 300 lbs. We have to all utililze the same rules so that may give you an idea of what a LS1 has as far as advantage over a LT1 in the same chassis.
Old 01-03-2012 | 05:37 PM
Longbob's Avatar
Never mind. I misread the question.
Old 01-04-2012 | 11:26 AM
- Heads must retain the factory 23 deg valve angle. Trick Flow 21 deg. heads permitted (PN TFS-30400008-M54).
- Must have stock-style suspension. 4-links and ladder bars not permitted.
- Independent rear suspension receives 200 lb. weight break.
- Must retain full OEM interior including both front seats. Aftermarket front seats permitted. Rear seats may be removed.
- Must retain OEM type transmissions of one of the following (700R4, 4L60, 4L60E, 4L80E, T56)
Its like the class was built around certain cars so some are in and some are out. Seems dumb but it doesn't really matter to my life.
Old 01-04-2012 | 11:46 AM
Tony Shepherd's Avatar
I am glad I am out of the equation now because of dumb *** whiney bitches like this. You have no clue man! The rules were never built around certain cars. Go whine to someone who cares.
Quick Reply: Planning for the next LTX shootout. What's with the LS1 PCM weight penalty?
