And the Fun Begins
Old Jan 8, 2012 | 09:10 PM
rich5368's Avatar
Default And the Fun Begins
Well I got my heads ported by LLoyd and ordered a cam but the parts all sat in my house due to the fact I ran out of money. My wife gave me the fundage needed for Christmas and I finally have all the parts and supplies together to get this thing started this week. This is my first Head/Cam swap on an American car so wish me luck Ladies and Gents.
Old Jan 8, 2012 | 09:24 PM
mcalus's Avatar
Congrats! I'm in the middle of my first too! What cam did you go with? I have LE's 226/232.
Old Jan 8, 2012 | 09:55 PM
rich5368's Avatar
Mine's close to that. It's an LE custom grind 224/234 .595/.613 on 1.7 rockers. Talking to Lloyd and the homework I've done on this site it should be a pretty good setup with the LE2s.
3DFORMULA's Avatar
Congrats and good luck with the project. I too am doing my first LT1 heads and cam swap.
Old Jan 8, 2012 | 09:59 PM
hvyss's Avatar
Should be a sweet setup.
Old Jan 8, 2012 | 10:05 PM
gregrob's Avatar
Like a boss
Old Jan 8, 2012 | 10:07 PM
rich5368's Avatar
Well it will run as you say "Like a Boss" when it gets that sweet gregrob tune. Can't thank that dude enough for the help.
Old Jan 9, 2012 | 07:03 PM
JCSWS6's Avatar
Congrats man, I just finished my build last week (heads, cam, converter, longtubes, ect) and it was a great feeling when it started. Lloyd talked me into a 228/236 cam on a 110 and it turned out great. Took it out this afternoon and when the converter flashes it is amazing. Lloyd told me it would feel like I was rear ended, he was right.
Just remember to take your time and quit when you get frustrated. I took over a month on mine because I just worked one project at a time (did it all alone). I used a pretty in-depth 12 page guide that can be found pretty easily and the GM manuals, they really helped. I ended up with a few hundred dollars more than I thought I would need in parts. Water pump drive was bad (was good enough reason to go EWP), motor mounts were sagging, broke the knock sensor, throttle cable was broken, and several other things that added up!
Best of luck to you!
Old Jan 9, 2012 | 07:29 PM
trilkb's Avatar
not to hi jack his thread but alot of good info in here...
Can you remove the heads without removing long tube headers? obviously loosen the header bolts on the cyl head, but do they need to be removed entirely? Maybe with the collectors undone they would drop enough to get access to the cylinder head bolts? or move far enough towards the fender wells to get to the bolts??
Im thinking of doing heads next but dont want to rip apart every thing, ive had enough fun with headers for the next 2 years.
Old Jan 9, 2012 | 07:41 PM
Zlow28's Avatar
"technically," you dont have to remove the headers completely off, but i cant see how thats physically possible. Theres very limited room as it is.
Old Jan 9, 2012 | 07:49 PM
JCSWS6's Avatar
I installed my longtubes while the heads were off and then installed the new heads. I have pacesetter longtubes and there was plenty of room to get the bottom bolts on the driverside. The passenger side was considerably tighter but moving it around a little worked fine (this was just to get the torque wrench on straight. It will make cleaning the deck a little harder though.
Old Jan 9, 2012 | 08:32 PM
rich5368's Avatar
Thanks for all the well wishes. JCS you brought up a couple things I hadn't even thought of yet. I fully expect to run into a few unexpected expenses. I'm doing the teardown myself but I'll have my buddy gregrob around to coach me through the reassembly so I'm pretty confident. I figure after 10 years of turning wrenches on Air Force aircraft and a few 4 bangers I should be able to handle it. lol
Old Jan 9, 2012 | 08:46 PM
JCSWS6's Avatar
Air Force Comm guy myself 13 years and counting Let me know if I can help
Old Jan 9, 2012 | 10:00 PM
Tinbender59's Avatar
OK I am a newbe to the LT stuff, so? who is Lloyd?? other than me , I wouldn't mind chatting with someone that knows their stuff!!! NAVY Avionics myself.25 years ago
Old Jan 9, 2012 | 11:10 PM
lt1slowz28's Avatar
lloyd elliott... www.elliottsportworks.com
Old Jan 10, 2012 | 11:23 AM
stuart4185's Avatar
do yourself a favor and just drop the engine out of the bottom of the car if you can. 6 bolts and boom it hits the floor, everything is easily accessable, and there is no fitment/dirt dropped in the oiling system
Old Jan 10, 2012 | 11:28 AM
lt1slowz28's Avatar
http://www.michiganspeed.com/enginepull/index.html
http://www.keliente.com/engine.htm
Old Jan 10, 2012 | 11:44 AM
stuart4185's Avatar
haha i was actually expecting a bashing instead of supporting comments. i guess im not the only one that has done things the "long way" in interest of not killing my back bent over and hours of aggravation for that one bolt you cant reach
Old Jan 10, 2012 | 11:50 AM
JCSWS6's Avatar
That is what I should have done but I had just finished redoing my whole AC and refused to break the seal. I still have to replace the motor mounts which could have taken me very little time if I had went this route
Old Jan 10, 2012 | 12:14 PM
lt1slowz28's Avatar
had I known better I would have done it for the headers. def doing it next time hehe.
