speedometer stuck on 150?
Old Jan 9, 2012 | 10:02 AM
camar0corey's Avatar
Default speedometer stuck on 150?
So last night driving back from PA about an hour from the house the waterpump crapped out. I shut down the car and coasted to the side of the interstate.
The speedometer is now stuck on 150? Any way to fix this? Car has a 24x conversion if that will influence anything.
Old Jan 9, 2012 | 10:09 AM
96TransAmboosted's Avatar
Well when mine gets stuck I do what I did to my old TV and smack the top or dash. A few good smacks and back to zero
Old Jan 9, 2012 | 10:58 AM
stevo9389's Avatar
^ shattered dash pad later
Old Jan 9, 2012 | 11:12 AM
food nd cars's Avatar
Stop going 150 mph.
Old Jan 9, 2012 | 02:21 PM
Never broke anything yet. Sometimes my tech gets stuck and I have to tap it.
Old Jan 9, 2012 | 02:30 PM
ahritchie's Avatar
Try bringing the car up to 160 MPH to dislodge the speedometer If you get pulled over, tell the officer the internets made you do it
Old Jan 9, 2012 | 03:18 PM
Puck's Avatar
Turn off your vtech, yo.
Lol its not too hard to pull the cluster lens, and if its just stuck then once you do that you can dislodge it.
Old Jan 9, 2012 | 05:15 PM
GreenBlood55's Avatar
post of teh day
Old Jan 9, 2012 | 05:30 PM
So the consensus is it is just stuck for some reason? Why did it go there in the first place? I haven't been 150+ in about three years or more now. I'll try the tapping the top of the dash method first as my dash pad is already junk.
Old Jan 9, 2012 | 06:18 PM
stevo9389's Avatar
when my electrical system was acting up sometimes either the tach, the speedo or oil pressure would peg itself for seemingly no reason and sometimes get stuck. never had the luck with hitting the console as it just put bigger cracks in the crash pad. happened on both my formulas and once on my supra. 2 of the times i had to remove the cover of the cluster and manually move the stuck gauge around.
Old Jan 9, 2012 | 08:56 PM
Yeah I just poked it back in that general direction and it finished going back where it belongs on its own. I did restart the car a few times while coasting to keep going a bit farther, so probably happened then. That eventually got old and I called up a tow.
Turned out to not be the waterpump itself either, the linkage was all chewed up?! On the driveshaft piece, motor side. Anyone else ever destroy one of those?
Luckily I've had a few motors come and go over the years around here. Happened to have one in good shape so I wasn't running around like a lunatic today trying to find one.
