LT1 to LQ4
Old Feb 7, 2012 | 05:51 AM
  #61
MattSapp95_T/A's Avatar
I by no means am knocking the LT motors I had one and my buddy has a AI 355 and runs awesome... My point it the statement that 460 to the wheels through an unlocked converter and a 9" is easily done is a bit misconceiveing... Can it be done? Yes as pointed out Joe is very close to that mark... Cheaper than a LSX platform is debatable... Bone stock LS3 heads on a bone stock LQ9 with a factory ls3 manifold, rockers throttle body properly cammed makes 550+ to the crank.. And getting better all the time..
Old Feb 7, 2012 | 08:34 AM
  #62
96lt1m6's Avatar
Maybe you should reread my post, did I say ANYTHING about ported heads? NO!
So lets try again, Lt1 w/stock heads plus a cam...... Ls1 w/stock heads and cam
Old Feb 7, 2012 | 08:48 AM
  #63
the_merv's Avatar
Veteran: Air Force
Originally Posted by 93Z2871805
Some are willing to drop $1k on a FAST intake (I myself haven't been impressed with the LS3/L92 version of the intake enough to lighten my wallet for one), I'll stick with the LS3 thanks, lol.
Yea I did alot of reading on that and decided to go with that Vic Jr setup I have..wasnt too impressed for 5hp gain for $1200 persay.
Old Feb 7, 2012 | 10:46 AM
  #64
Ls wins everytime
Old Feb 7, 2012 | 10:47 AM
  #65
FlatBlackZ28's Avatar
I might have misspoke a time or two. I was pointing more to the costs of building an LT1 over and LS1 and the fairly close power level that can be had for around the same amount of money (if someone was starting without either engine.). Not really an LT1 vs. LS1, LS2, LS3, LS4, LS7, LS9, LSA, LQ9 etc etc etc. (the entire LSX family) The advantages of these LS3 heads on an LQ9 block are clearly larger than that of an LS1 head on an LS1 block, given that the LS1 came out the same year as the last LT1 and the LS3 came out over a decade later.
Old Feb 7, 2012 | 11:14 AM
  #66
93Z2871805's Avatar
Veteran: Air Force
I don't know how plentiful LSX and LTX engines are by others, but 5.3s get $525, 6.0s get $950, and LT1s get $850-$1500 by me (even Vortec 350s pull $1300). They are all pulled the same way, wiring cut, fuel lines cut, accessories stripped, but otherwise complete. So (by me), the LSX engines are cheaper to source and build, but the LT1 cars are 2-3x cheaper to buy.
Old Feb 7, 2012 | 11:58 AM
  #67
When I bought my LT1 donor car back at the end of 2007, I got the entire car for $1000. Complete engine, tranny, rear end, exhaust, pcm etc etc etc. It was the norm for what I had found.
The engine in it still runs great, and I'm only now upgrading the bottom end because I want more power.
Old Feb 7, 2012 | 12:58 PM
  #68
96lt1m6's Avatar
The bottom end can be redone with better parts best cost effective way I know of is CID 383,385,388,396 with 11:1- possibly 12:1 compression and of course a head and cam combo from LE or AI then of course all the complimenting mods that will support the set up.
Old Feb 7, 2012 | 03:25 PM
  #69
The bottom end (in my scenario) will allow for more power than a set of AI heads/cam would. Not because the bottom end itself will be making any power, but because it will allow me to rev my CC306 where it needs to be and also hold up to repeated 150 hits of sauce.
Old Feb 11, 2012 | 12:23 PM
  #70
davidc212k's Avatar
will the stock LQ4 alternator bracket with the alternator on, clear the hood?
i want to keep emissions. so keeping EGR with connections. changing waterpump to ls1 style. want to keep the alternator on the drivers side with the power steering.
does this seem like an option?
http://www.ebay.com/itm/New-LS1-High...sories&vxp=mtr
im sure il be missing some pulleys.
Old Feb 11, 2012 | 03:35 PM
  #71
the_merv's Avatar
Veteran: Air Force
That wont fit..F-body Accessories are the way to go.
Old Feb 11, 2012 | 05:24 PM
  #72
davidc212k's Avatar
By that said. The stuff on the link do work?
Old Feb 11, 2012 | 05:35 PM
  #73
the_merv's Avatar
Veteran: Air Force
No, that or the Truck stuff I would steer clear from IMO..
Old Feb 11, 2012 | 05:41 PM
  #74
davidc212k's Avatar
i found this ? http://www.ebay.com/itm/98-02-LS1-Ca...item53eb27f7d7
Any image i can use as reference ?
il use the following page as reference.
http://www.trifive.com/forums/showthread.php?t=35561
The F-body (Forth Gen Camaro/Firebird) LS1 image.
Can anyone tell me the parts i need? like the pulley etc.
Old Feb 11, 2012 | 07:24 PM
  #75
the_merv's Avatar
Veteran: Air Force
F-body & GTO use pretty much the same stuff.
You need:
Crank Pulley
Car Waterpump
Car Power Steering with Resevoir, Pulley & Brackets
Car Alternator with Brackets.
Old Feb 11, 2012 | 07:46 PM
  #76
SSmoked1's Avatar
I did my swap like 4 years ago. Originally was looking for a wrecked LT1 donor car but ended up finding a 99 Z28 with 80k miles for $2k on the forums. Didn't know anything at all about LS1's but bought it anyways. ALL info I learned was off this forum and majority was reading merv's thread. Your going to need to do a ton of research but it really fun and not that bad.
Old Feb 11, 2012 | 08:02 PM
  #77
davidc212k's Avatar
are those 2 serpentine belts? If so, any part numbers? or names i can go buy
Old Feb 11, 2012 | 08:05 PM
  #78
SSmoked1, how's it going? Are you going to make it back to Thompson this year? I was making some good progress with the setup I had last year until I ran into some ignition problems. I have since started my forged bottom end build, installed a nitrous kit and added the LTCC conversion. Won't be able to shell out for AI heads until this time next year unfortunately.
Look forward to seeing you at the track in a couple months.
Old Feb 11, 2012 | 08:14 PM
  #79
SSmoked1's Avatar
Hey what's up!!? Sounds badass. How's that thing running with a shot? I always dreamed of the LTCC when I had an LT1 lol. I plan on spending a lot more time at the track this year. I have a 12 bolt with 4.11's/full suspension waiting for a warm day to install. I was always scared of killing the 10 bolt.
Old Feb 11, 2012 | 08:15 PM
  #80
the_merv's Avatar
Veteran: Air Force
Go to Orielly's..
2002 Camaro Serpentine Belt, LS1 5.7
2002 Camaro AC Belt, LS1 5.7
