Lifters?
Old Jan 22, 2012 | 05:22 PM
zraffz's Avatar
Default Lifters?
LE made a suggestion on running a 236/244 .608"/.608" 110 LSA cam behind my 357 LT1.
I currently have a set of LS7 lifters, will they work with that grind? I don't have a retaining plate or link bars yet. I'm kinda wondering if it's worth running a set of lifters that have the link bar built into the lifters?
Old Jan 22, 2012 | 06:45 PM
96LT1355Z28's Avatar
The LS7's should be just fine. You'll need the "spider" and the "dog bones" to keep the lifter straight. The link bar lifters are more commonly used in non-roller blocks.
Old Jan 22, 2012 | 07:21 PM
TravisMcGill2000's Avatar
Wat he said. Im running same cam and lifter
Old Jan 22, 2012 | 07:28 PM
zraffz's Avatar
Along the lines of the stock spider and dogbones like this, right?
http://www.summitracing.com/parts/EDL-97386/
Old Jan 23, 2012 | 11:11 AM
sweetbmxrider's Avatar
My ls7's were crap out of the box. No oil to the top end. Got some lunati link bars and can't be happier.
Old Jan 23, 2012 | 11:32 AM
mcalus's Avatar
Not trying to go off topic of op's thread but what's with the dog bones? Or spider?
I got new ls7 lifters and a 226/232 cam.
Old Jan 23, 2012 | 12:12 PM
quik95lt1's Avatar
dog bones connect the lifter bodies together on the flats in the side of the body to stop them from rotating in the bores.........dog bones pair them together and the spider is just a spring steel piece that holds the dogbones down on the bodies so they dont pop off .......
Old Jan 23, 2012 | 12:15 PM
BOLO's Avatar
It's the stock retainer/plates in the lifter valley to help keep lifters in place.
Old Jan 23, 2012 | 12:47 PM
mcalus's Avatar
They don't come stock with dog bones correct? Are they needed with every aftermarket cam?
Old Jan 23, 2012 | 01:26 PM
FormulaJoe's Avatar
They do come with dog bones and spider stock and are needed if using stock type lifters.
Old Jan 23, 2012 | 01:58 PM
mcalus's Avatar
Ok, I'll have to look in my bag of old ones, I don't recall seeing the dog bones.
Thanks everyone!!!
Sorry op
Old Jan 23, 2012 | 03:01 PM
zraffz's Avatar
Thanks everyone!!!
Sorry op
If you look at the link I posted from Summit it will show you what the dog bones and spider retainer plate look like. I just wanted to double check their isn't some better design than stock.
Old Jan 23, 2012 | 03:18 PM
quik95lt1's Avatar
there is lol......the link bar lifters but you are going to dig deeper in your pocket for them vs the LS7's which are fine for your application.....
Old Jan 23, 2012 | 09:42 PM
mcalus's Avatar
Ok, I had a blond moment, just reinstalled the stock dog bones and spider. I don't recall taking them out 2 years ago, but I found them next to the old lifters. This is my first build. Thanks again guys.
Old Jan 23, 2012 | 10:22 PM
FormulaJoe's Avatar
Hey it's easy to forget those small things when your thinking about the big picture.
Old Jan 24, 2012 | 07:57 AM
quik95lt1's Avatar
yyyyeeaaaaaaaa.......those would be a realllyyyyyyy bad thing to forget about lol
Old Jan 24, 2012 | 11:27 AM
FormulaJoe's Avatar
Hahahaha
Yeah, forgetting anything is cause for some bad things happening!!
It's easy especially with first builds to miss things... But definitely no excuse! Gotta triple check everything.
