Thunderchicken w/ Advanced Induction 21deg CNC'd TFS Heads & HR Dyno Results
#101
Haven't been able to get on the forums in awhile, figured you guys might like some answers.
Yes, it makes more area under the curve and average power, but the peak difference isn't going to be huge - the head is the biggest factor by far. Never heard a lobe described as "lazy," that strikes me as internet jargon from guys w/o data. I suppose there are people who consider the XE series mild, but I do not. How is the "split" more favorable for an NA application? How does one determine that from .050" #'s? I don't make a habit of selling myself short, but neither do I care to bullshit guys about how the cam makes all the difference in the world insofar as output goes. Unless something is out of the park w/ one grind, similar cams tend to make similar #'s if they are both under control.
Cams are simple - most guys just have no data. Most all of the cam companies have milder lobes than what is popular.
Depends on setup. CNC'd GM LT1's are a better choice for the majority of stock short block applications in my experience.
Same as a similar 23deg head. Nothing particularly special about a 21deg valve angle - it does not get you a quarter of the way to a 15deg sbc head, just smaller available chamber volumes. I do SR setups on the 21deg head w/ the .700" Nextek dual spring option listed on the site.
In all the years I've done this, I don't think I have ever had an LT guy truly want a max effort NA build. The overwhelming majority will never spend the $ on short block and valve train to run the current heads we offer run to potential.
I've offered to do a setup for guys who want a large 23deg, converted 12-18deg, etc. LT setup, but have never had the 5-8 guys step up and send in deposits to get something like that going.
Alan - so this is all Frank's fault, eh. Maybe that is just his devious plan to eliminate his competition - convince them all to invest in things that, half the time, keep them from getting to the events.
Glad you guys like it, take care.
-Phil
Honest question, you really think only ~10-15hp was from the cam swap? XE lobes are very mild, surely the cam you specced is using quite a bit more aggressive lobes? (I'm not asking about them, I understand from a business stand point you can't talk about the lobes you use and spec...which would be way more insightful information then just knowing the duration @50). It also has a more favorable NA split, quite a bit more lift, and a healthy amount of duration. I can't imagine your larger, modern custom cam NOT making a sizable difference both under the curve and @ peak over the old lazy XE lobed 236/248 grind that clearly wasn't specced for big NA power on a stroker.
Like I said, it doesn't really matter since you provided a bolt-on PACKAGE that eliminates the trial and error, and the proof is right there that it works as a whole...I just feel you are selling yourself short on the benefits of a modern, properly specced camshaft.
-Phil
#102
-Phil
-Phil
#104
Quote:
Originally Posted by Puck View Post
The 21* TFS are badass heads still, and seemed to work more then good enough on this medium cammed 6500rpm 396, but just don't have the size to feed a max effort high rpm stroker.
Getting around 500RWHP is amazing! I have a question for you, Phil. I am planning a high TQ 396 in my future. I dont want to rev the thing to 7K RPMs and im NOT looking for absolute highest RWHP. I might drage race a couple times a year at most.
I am looking to build a torque monster that will be a lot of fun to drive on the street. The thing that intrests me about these 21 degree heads is that I would think the slightly smaller size (212) vs the 215 for the 23 degree TFS head you do would make for really great bottom end grunt. If I was going to rev a 383 to 7K, I could see how the 215cc 23 degree TFS heads might be a better choice for an all out power machine.
What is you opinion on a high TQ 396? I wouldnt mind seeing SLIGHTLY higher TQ numbers than the graph you posted on the first post, even if it meant lower RWHP numbers. Would you say the 21 degree 212cc TFS would be the right choice for me?
I would probably want to redline no higher than around 6500-6700 in order to keep my power band starting as low as possible. Most likely run 11.5:1-11.9-1 compression and have you guys port my LT4 intake manifold out as far as it will go and use a monoblade throttle body and 1 7/8" headers if nessecary
The following users liked this post:
NewOrleansLT1 (01-22-2024)
