OBX Headers (just recieved)
Old Mar 10, 2012 | 01:33 PM
  #201
The Batman's Avatar
I looks as if you can. They have them listed for $415
Old Mar 10, 2012 | 07:20 PM
  #202
Valkyn's Avatar
Moment you have all been waiting for...
Got a chance to install the drivers side header. I'm going to wait to install the passenger side one until I get some heat resistant/reflecting tape I want to put on the wiring and AC line down in there.
Anyway the drivers side literally just fell into place no problem whatsoever. It was way harder to remove my old Jethots than install the OBX. I had the bolts out of the motor mounts and the engine jacked up away from the K-member as far as i could. I do have a tubular K-member so your mileage may vary with the stocker.
The only issue so far is that they made their copy of the Kook's alittle too close to the original, the OBX also have the issue the Kook's do with hitting the oil filter. I tried beating the regular filter with a hammer to clearance it and got it so it was not hitting the header (by 1/16" or so) but still didnt like it.
I searched around the internet alittle and found that the PH-454 Delco oil filter will fit our cars and is about an inch shorter than the standard filter. I bought one and was able to install and remove it with the headers in place. I'm happy with the short filter, I think if you wanted to run a normal filter with the edge smashed in alittle bit you would be ok but you would need to take the headers loose at the head and push the collector over an inch or so to change the oil filter.
The steering shaft clearance is amazing, all kinds of room. Note in these pictures I still have the motor mounts loose but I think its sitting pretty close to how it will be with the mounts installed. I was able to get to all the header bolts pretty easily also. I used the 1" ARP 12 point head style. I am waiting on my Br7ef spark plugs to come in next week, so will get info on plug access then.
I may try to install the passenger side tomorrow, if its goes in as easy as the drivers I will put it on temporarily and get some pics.
Old Mar 10, 2012 | 07:29 PM
  #203
sandman2100's Avatar
Nice! Looks as if they are going to hang a bit low from the pics tho?
My LPP's took some beating and grinding of the steering shaft to fit. I would have loved to have that clearance!
Old Mar 10, 2012 | 07:32 PM
  #204
Valkyn's Avatar
They dont look too low, I was hoping they would be alittle lower for the exhaust actually. Ill get a pic later.
Old Mar 10, 2012 | 09:26 PM
  #205
97pontta's Avatar
Is there any chance I can get you to measure the distance from the bottom of the collector straight up to the floor of the car? Even better yet do you know how the OBX header set for ground clearance compared to the jet hots you had?
I've got JetHots right now and can't afford to lose any ground clearance due to my car being lowered. I'm looking really hard at buying a set of these but wouldn't if they were 1/2 inch or more lower than the JetHots.
Old Mar 10, 2012 | 09:38 PM
  #206
Driftunit's Avatar
looks pretty good to me, for the price i can deal with having to buy another oil filter lol.
Old Mar 10, 2012 | 11:38 PM
  #207
1961ba427's Avatar
I'd bet they will be a little closer to the ground due to the 3.5" collector compared to 3" for JetHots and most others...even if they tuck up a little closer to the floor. Then again it's only .25" in each direction.
Old Mar 11, 2012 | 12:38 AM
  #208
The Batman's Avatar
this is awesome to finally see!!
Old Mar 11, 2012 | 03:08 AM
  #209
mcalus's Avatar
Where are y'all getting your stainless reducers?
Got my lpp ORY today, need to start modifying it...
Old Mar 11, 2012 | 10:23 AM
  #210
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
If they did a good job of cloning Kooks, you'll have to remove your oil cooler, assuming you have one, and run a shorty filter.
Old Mar 11, 2012 | 11:21 AM
  #211
Valkyn's Avatar
I dont have an oil cooler.
Yeah no way your running these with one.
Old Mar 11, 2012 | 12:02 PM
  #212
SoxXpupPeT's Avatar
The same with my ap1ap2 headers. I had to do so much to get them to fit properly around my steering shaft
They look great in car OP
Old Mar 11, 2012 | 05:25 PM
  #213
93v8clone's Avatar
Is there a phone num to get ahold of these guys .
Old Mar 11, 2012 | 05:44 PM
  #214
Valkyn's Avatar
We must have bought all the OBX places out of stock lol. Super saver accessories dosent list the product on their website anymore, the other retailer OBX lists on their site dosent show them either.
http://www.obxracingsports.com/authorized_dealers.php
Old Mar 11, 2012 | 11:23 PM
  #215
badfbodyz's Avatar
i can also say that these headers LITERALLY fell in place on both sides on my car. i didnt even have to disconnect my motor mounts. my steering shaft clearance is great and there are no rubbing issues at all. BY FAR the best set of headers for these cars for the money. the have the same exact bends as the kooks headers. and they are even stepped from 1 3/4 to 1 7/8. you will not be dissapointed if you get a set of these!
Old Mar 12, 2012 | 08:59 AM
  #216
2cat95ta's Avatar
I regret ordering these now lol hopefully they get them in stock again
Old Mar 12, 2012 | 10:13 AM
  #217
The Batman's Avatar
Originally Posted by 2cat95ta
I regret NOT ordering these now lol hopefully they get them in stock again
fixed ^^ lol
Old Mar 12, 2012 | 01:12 PM
  #218
warriorcustoms's Avatar
Yeah no OBX dealer in the nation has any LT1 headers. The sales guy at ERZ & EracingZone said itll be minimum 30 to 60 days before any are available That sucks. If anyones too lazy to install theirs I will buy em LoL
Old Mar 12, 2012 | 05:47 PM
  #219
2cat95ta's Avatar
Originally Posted by The Batman
fixed ^^ lol
Thats what I meant to put haha
Old Mar 12, 2012 | 09:17 PM
  #220
mcalus's Avatar
Just an FYI, the lpp ORY fits mine great. Obviously with reducers but other than that it lines up nice
