Cylinder #2 Piston MISSING !!!
Old Feb 17, 2012 | 02:58 PM
great421's Avatar
Originally Posted by WS Sick
Since the exhaust valve is missing whats the chance you droppd that sucker causing the carnage?
Only half of the valve is missing, the top half and spring are still attached to the top of the head; I suspect that the root cause is a shattered piston.
The driver's side head and oil pan come off Monday - more pics to follow.
Old Feb 17, 2012 | 03:19 PM
Mystery Bird's Avatar
That must of sent chills up your spine when it let go. I'd say you goy your money's worth from that engine. Nice Job!
Old Feb 17, 2012 | 07:34 PM
SoxXpupPeT's Avatar
Impressive on all accounts! First off the mileage but then to have boost and meth for that long? good tune! lol
Old Feb 17, 2012 | 07:44 PM
3DFORMULA's Avatar
I got dibs on the custom worked heads! WOW, impressive lasting ability
Old Feb 17, 2012 | 08:09 PM
GreenBlood55's Avatar
me thinks you need to change you current configuration. =)
Old Feb 20, 2012 | 08:04 PM
great421's Avatar
Default LT1 Carnage Part II - Wrath of Con(rod)
My #2 Con rod was ever so slightly bent (See PIC).
My builder suspects the "GMA 599" callout cast into the big end of the rod indicates it is / was a stock GM powdered metal rod (any thoughts???), but whoever made it - GM or the aftermarket - it sure took a beating and stayed together!
Also, found the 'head' of the exhaust valve in the oil pan, along with the remains of the #2 piston - it was in 1000+ pieces.
Old Feb 20, 2012 | 08:16 PM
CamaroZ28_LS1's Avatar
man I am not even mad at this, I am impressed. sorry to hear about the motor. Time for upgrade.
Old Feb 22, 2012 | 12:44 PM
AChotrod's Avatar
Just put that rod in a vice to straighten it and it will be as good as new!
Old Feb 22, 2012 | 01:13 PM
bowtienut's Avatar
oh.........and a little buffing wouldn't hurt either
Old Feb 22, 2012 | 11:01 PM
Rodinator1234's Avatar
That is very impressive it lasted that long. What turbo set up are you running? Cool pic's too. Those are items to keep in the shop and tell stories about.
Old Feb 23, 2012 | 08:24 AM
quik95lt1's Avatar
yeaaa nbd just heat that rod up and bend er back just a minor wound haha
this is great though.......yet another example where the "brittle powered metal rod" bent and didn't shatter....... +1 for the good guys haha!! lol
Old Feb 23, 2012 | 12:24 PM
  #32
AChotrod's Avatar
Lol He can prob just JB weld that piston back together also!!
