Getting close! (Whipple LT1 Pics)
Kinda of dumb question but did you do anything with the IAC path? Since the stock intake has air bleed holes going to each cylinder via the intake runners. I guessing split blms for life though
Is the stock throttle cable going to work or are you using like a lokar or something else?
I'm pretty sure you now own the only LT1 any other LT1 owner would be willing to kill for lolAlso ironic, your car is green, so is mine! You should prob send me a set up so we can match lol
From: windsor, ont. canada - Home of the fastest LT1 6spd.
Been doing some research intercoolers can be had through companies like Griffin (custom made) for around $600, but you still have to plumg a heat exchanger and pump. I think meth is the best intercooler anyways. At normal driving IAT's will stay close to Ambient, when into throttle Meth kicks in lower IAT's.
I am in the process of doing a 2.9 whipple system as well. Almost done with my base manifold. Not as slick as BBK's but it will work
I want one for my C4 Vette... Is this just for f-bodies or can it be adapted to fit in the c4 engine bays. If u want to us my car as a test mule I'll let ya
