Need some help FAST please
Old Feb 29, 2012 | 02:54 PM
needtransam's Avatar
Default Need some help FAST please
Ok so first my door wouldnt open with the keyless entry, now I went outside to check the door and it didnt close all the way so I try to close it and it doesn't want to close?
1994 z28 driver side door doesn't close at all not sure what it is need help
Old Feb 29, 2012 | 02:59 PM
katz_2003's Avatar
This is hard to explain...the female part on the door has a little lever latch thing that you can flip up with your finger. It is probably closed and is blocking it from latching onto the male **** sticking out of the body of the car. ....sounds kinda dirty, but. That's the best I got lol
Old Feb 29, 2012 | 03:03 PM
blacktrans97am's Avatar
I agree with the above poster. Take a screwdriver and open the latch up on the door. Then spray it down with some lubricator, I usually use WD-40, and work the latch open and closed multiple times.
Old Feb 29, 2012 | 03:08 PM
yeah i know what latch you mean i think its just gone do you know how much is to replace, the bad thing is that im at work and not sure how to drive back to my house with the door like that
Old Feb 29, 2012 | 03:10 PM
You mean gone like it not there anymore?? It really cannot go anywhere but into the door.
Old Feb 29, 2012 | 03:11 PM
no like i think its gone in the sense that its not working at all i guess the only way is to take it out of the door so i have to take out the door panel and the three torx screws and that is it?
Old Feb 29, 2012 | 03:17 PM
There are some rods connected to it as well. Honestly though, I would try lubing it up before replacing it. Work 9 out of 10 times.
Is it in the closed position now? If so, just lift up on the door handle with one hand and push it to the open position with the other. If you can do that your door will close and latch. You just might have to do it everytime you open the door till you either replace it or lube it.
Old Feb 29, 2012 | 03:23 PM
i see uhmm well ill try it hope it works
Old Feb 29, 2012 | 03:25 PM
05HD's Avatar
In order for the door to open, that latch had to be in the open position. Only way it got closed with the door open is you bumped into it either with part of your body or something you were carrying.
Make sure the door is unlocked, actuate the outside handle and push the latch open with a screwdriver or a pen or something. It pivots down to open so you will have the best leverage pushing from the top edge.
Old Feb 29, 2012 | 03:32 PM
Ok I kinda do get it but do you have a picture or something, its cause when I looked at it I think the little latch was like not even in position like its around the 11 o clock position?
Old Feb 29, 2012 | 03:50 PM
katz_2003's Avatar
The latch needs to be facing straight out...towards the male end or it will hit it and not close
Old Feb 29, 2012 | 03:53 PM
yeah but when i look at both latches the drivers seems completely different not even the same as the passanger side
Old Feb 29, 2012 | 04:09 PM
ok I think this is the one im looking for?? a friend has one he said $20 bucks but does it look good?? how can I tell ??
Old Feb 29, 2012 | 04:33 PM
katz_2003's Avatar
I doubt yours is actually bad...try to lube it up like others said with penetrating oil or wd40 and it should work fine. Did you get that little lever in the right position so it would close?
Old Feb 29, 2012 | 04:53 PM
well i tried to but its wierd i can't even put it like in normal position might be stuck with something else, when i bought the car you had to almost slam the door for it to close so I think its bad
