At what point do you recommend ARP Rocker Studs?
I'm going to be running a HotCam/1.6rr set up and valvesprings with 130lbs seat pressure, 340ish at full lift. My rockers are 3/8" studs. Should I go ARP?
IMO the time to go ARP is when you buy your first set of rockers, just go right ahead and buy 7/16" studs, guideplates and non-SA rockers the first time so you don't have to do it all over again when the next stage of modification comes around.
Spend a little more now and save a good bit later.
I realize it is probably too late for the OP sounds like you had the rockers and that had you boxed into 3/8" stud but I still wanted to put it in print for the next guy.
I bought too many sets of rockers for various stages of modification wasted a lot of money buying "good enough" and outgrowing it.
