What is this part?
Old Mar 15, 2012 | 02:47 PM
HarryNutz's Avatar
Default What is this part?
On a 96 Z28
I have no idea what this part is... the one thats black with the silver tube coming up from god only knows what and goes into the rear of the black part and then a black elbow hose comes out the front that you see just behind the fuel line.
A buddy told me PCV... a local parts shop said EGR... someone else said secondary air injection relay and another said secondary air injection valve.
I need to replace that elbow hose cause its cracked and leaking and without knowing exactly what it is, makes it hard to call around and try and find a replacement
Old Mar 15, 2012 | 02:53 PM
93M6Formula's Avatar
It's a check valve for the AIR injection sytem. It's emissions related.
Old Mar 15, 2012 | 02:57 PM
notsue's Avatar
Yes, its for the AIR crap... I wish my engine bay was as clean as yours...
Old Mar 15, 2012 | 03:00 PM
shbox's Avatar
GM PART # 10217106
Secondary air injection check valve pipe connector
Old Mar 15, 2012 | 03:07 PM
itSSlowZ28's Avatar
Holy cleanliness
Old Mar 15, 2012 | 03:08 PM
HarryNutz's Avatar
Thanks guys, so for sure a dealer part and not something I would find at a parts place.
Was wondering if this part leaking would at all cause a check engine for a bad o2 sensor? From what I hear the o2's are a pain to replace and of course the one thats actually bad is worst to replace of them all (again from what i have been told) the one on the passenger front...
Old Mar 15, 2012 | 03:09 PM
HarryNutz's Avatar
Guys... it saddens me to say... that is not my engine compartment. I had to search high and low on Google to find a picture that showed that valve.
Old Mar 15, 2012 | 03:27 PM
HarryNutz's Avatar
Good deal man, appreciate it. And hello from up here near Mountain Home AR. Just moved here from Ohio and found out we are in tornado alley and even had my first warning sirens waking me up at 3 in the morning a few weeks. I don't like it... lol... and wanna go back to the worst thing to worry about was a bad ice storm haha
Originally Posted by shbox
GM PART # 10217106
Old Mar 15, 2012 | 04:17 PM
shbox's Avatar
All you had to do was go to my website.
I gave the GM number, but it may be available aftermarket.
We have tornadoes and ice storms (and most things in between). Be glad you live in a town that has sirens. A weather radio with S.A.M.E. programming is a good thing to have.
Old Mar 15, 2012 | 05:03 PM
HarryNutz's Avatar
For like $8 may as well stick with dealer as I would have no clue where else to look, that is if the morons ever call me back. Called 4 times and always says leave message, so here I wait after leaving a message. Must be the busiest parts dept in the state lol.
I would prefer to have a bunker... that or the ability to move back to where I was in Ohio or my home town near Philadelphia.
Old Mar 15, 2012 | 06:48 PM
F0x Slaughter's Avatar
Just do what I did. Put on race long tubes, remove AIR and EGR and cut the AIR pipe out.
Old Mar 16, 2012 | 08:42 AM
warriorcustoms's Avatar
I dont think they have smog checks there So I would just get some headers & delete that bullshit Get headers without the egr & get block off plates for the intake & be done with it Your engine bay will be much cleaner & lighter lol
Old Mar 16, 2012 | 09:30 AM
HarryNutz's Avatar
I just need to fix these couple problems, cause I want to sell the car and then just get a beater A to B car thats more economical for me. Anyone have a clue what I might be able to get privately?
Its in excellent condition, no rust or dings and the only real issues are it needs to air conditioner recharged, small crack in the dash thats barely noticeable in the middle near where the venting comes out and the small flap piece thats angles up and over the rear trunk space for the T-Tops go has a broken piece off one side so it doesn't exactly sit right. other then that... the car is pretty solid.
Had the trans replaced 2 yrs ago along with a lot of other work (though with moving I lost receipts). But currently this is what is installed:
110k miles:
SLP CAI
SLP Cat Back Dual/Dual
SLP Bolt-On SFC
SLP STB
Throttle Body Cooling Bypass
LT4 Knock Module
160 Thermostat
Doug Rippie 52MM TB/Ported Air Foil
New Jasper trans installed 2009
3.42 GM Rear Gears
Spohn Moly Adjustable Torque Arm
BMR Chrome Moly Adj. Panhard Rod w/Rod Ends
G2 Tubular Control Arms
B&M Shift Kit
2002 Front and Rear Sway Bars
TrickFlow Ceramic Intake Elbow
HPP+ Programming (Performance, Lower Fan Cycle, 3.42 Rear Gear Change)
Ultra Z Hood w/MBA Stainless Steel Inlet Cover
1996 Z-28 SS Rear Spoiler
17inch 2000 Z-28 SS Rims
1968 Z-28 Side Emblems
1998 Z-28 Leather Door Panels
1998 Z-28 Rear Leather Seats
Carbon Fiber Gauge Panel Overlay
Stainless Steel Relay Cover
Stainless Steel Oil Cap
Stainless Steel Radiator Cap
Stainless Steel Rear Camaro Letters
Stainless Steel 2002 Z-28 Rear Emblem
SLP Rear Emblem
Haddon 5.7 High Output V8 Badge
Old Mar 17, 2012 | 12:55 PM
HarryNutz's Avatar
So nobody wants to take a stab and my private sale question?
