Strange knock/vibration
Old Mar 15, 2012 | 04:03 PM
97 Trans Am ws6's Avatar
Default Strange knock/vibration
Last night i had a mustang race me light to light and when taking off from the light there was a banging vibration coming from right under my console, only happens when you take off hard from a stop, otherwise there is no vibration or noise, thinking i might have torn the trans mount but haven't gotten a chance to get the car up to look at it. How likely can you do that and if thats the case are they very hard to replace?
cars a 97 a4
Old Mar 15, 2012 | 04:24 PM
blakez28's Avatar
I'm guessing trans mount too.
Old Mar 15, 2012 | 04:43 PM
sandman2100's Avatar
Check the torque arm as well. I had a vibration at the shifter on accel and decel and it was cracked/split at the axle mount when I bought my car. Only way I found it was when it finally gave way and was hitting the DS.
Replaced it and it was smooth as silk.
Old Mar 15, 2012 | 08:21 PM
checked the torque arm and seemed solid and straight
Old Mar 15, 2012 | 08:52 PM
mbowtie71's Avatar
What about the Mustang that you raced? Did you beat him? And yes it sounds like the transmission mount.
Old Mar 15, 2012 | 09:31 PM
mustang was only cai and exhaust 4.6, first 2 runs i destroyed him, last one i shut down because of the vibration
Old Mar 16, 2012 | 08:46 AM
93M6Formula's Avatar
Yes it's possibly your Trans mount. I had that happen 2 years ago with my 6-speed. Everytime I got on it, the shifter would shoot up like 3 inches haha. Definitely wasn't good!
Old Mar 16, 2012 | 08:51 AM
slomarao's Avatar
DS possibly if its not the trans mount.
Old Mar 16, 2012 | 11:44 AM
ahritchie's Avatar
Almost certainly trans mount; thumping, excessive movement in the shifter....been through 5 of them over the last 15 years (yes, I beat on it ). The last one I broke was even an Energy suspension poly mount with the interlocking metal internals...lol. Had some severe axle hop when I had to slam on the brakes in the rain due to an idiot that pulled in front of me and it busted. That said, the poly ones do last much longer (that one was over 5 yrs old when it broke) and make the shifts feel MUCH more positive. It's definitely worth the extra $10 for a poly mount.
Oh yea, and takes like 10 minutes to replace
Old Nov 13, 2012 | 09:32 PM
Blackmomba65's Avatar
Have u found the problem?
I have the same problem with my car changed the trans mount to a poly and it still vibrats and makes that knock noise. I put after market umi tunnell mount torque arm.I'm thinking drive line or shock. I checked the drive line it looks fine but I'm going to change the u joints anyways.
