230/236 on a 110lsa DYNO!!!
Old Mar 15, 2012 | 08:12 PM
NewOrleansLT1's Avatar
Default 230/236 on a 110lsa DYNO!!!
Well with AFR 180 heads and Hot Cam with unlocked 3500 stall I made 340rwhp. All I did was swap the damn cam to a 230/236 110lsa and put it on the dyno. With a lean 15:1 a/f it made 362rwhp at 6400 rpm. With a little tuning it made 374 rwhp at 6400 rpm. This is through pacesetter mids and a cutout! I could have spinned the motor a little higher but Geoff at EPS didn't recommend it. Thanks for the great work Geoff...
Old Mar 15, 2012 | 08:34 PM
95mysticta's Avatar
Wow you ran it to 6400 with A/F at 15:1
When your a/f is that far out you shouldnt be running to that kind of rpm. Once you see it dip down you should stop and go back and edit your tables to get it closer inline. Im amazed it didnt go boom on a stock shortblock
Old Mar 15, 2012 | 08:38 PM
TravisMcGill2000's Avatar
Congrats good numbers. Is it still on stock rear?
Old Mar 15, 2012 | 08:42 PM
I told him to dyno as is. OOPS!!!
Old Mar 15, 2012 | 08:45 PM
Yes, but I will at least get a TA girdle...
Old Mar 15, 2012 | 08:55 PM
Rob94hawk's Avatar
Nice! Mustang dyno I'm assuming?
Old Mar 15, 2012 | 10:01 PM
Thanks. Its a Dyno Jet (with a unlocked 3500 stall)
Old Mar 15, 2012 | 11:38 PM
Puck's Avatar
374 is very respectable with baby heads, unlocked stall, and through Mid tube headers.
Grats!
Old Mar 16, 2012 | 06:32 AM
bufmatmuslepants's Avatar
Grats!
And through an auto, nice numbers
Old Mar 16, 2012 | 08:30 AM
Thanks guys. My rwtq was 330 at 4700. That seems a little low to me. I was expecting a minimum of 350rwtq. What you guys think? Is the stall obsorbing torque or is the mid tubes hurting torque? Or???
Old Mar 16, 2012 | 09:10 AM
transbird95's Avatar
Not too shabby, good job!
Old Mar 16, 2012 | 09:28 AM
96capricemgr's Avatar
A torque converter is a multiplication device. It isn't hurting your torque number.
Old Mar 16, 2012 | 09:38 AM
Well he started the pull at like 4500rpm so I don't know the the torque numbers before that, maybe it could have been higher...
Old Mar 16, 2012 | 11:12 AM
gjohnsonws6's Avatar
What lobes are you using?
Old Mar 16, 2012 | 11:51 AM
slomarao's Avatar
For those small heads thats a good amount of power. nice work bud
Old Mar 16, 2012 | 05:15 PM
Thanks guys. I'm using the XE 230/236 .510/.520 on a 110 lsa with 1.7rr
Old Apr 9, 2012 | 08:57 AM
Just found out that my numbers are SAE. Now I'm really impressed!! Just thought I'd share with you all...
Old Apr 9, 2012 | 09:20 AM
Article in the latest GMHTP and the dynojet 224x showed 394rwhp where the Mustang was 369rwhp and the dyno dynamics was 366rwhp. That is a 6-7% higher than the other two brands.
Old Apr 9, 2012 | 11:01 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
its NA relax buddy.........
Old Apr 9, 2012 | 01:58 PM
I was told that SAE shows 10-15rwhp LESS than STD...
