Need Cam Help!
Old Mar 17, 2012 | 05:40 PM
Luedy239's Avatar
Default Need Cam Help!
Hey guys. Im looking to put a cam in my LT1, with i pulled out of my 94 camaro to rebuild. Does anyone know which cams i could use that wouldn't require may other upgrades? Im running on a tight budget, so i don't want to spend much. Does any one know how good the CC304 or CC305 cams are? And what would they require to run properly? Thanks
Old Mar 17, 2012 | 06:10 PM
RamAir95TA's Avatar
To do a cam swap properly you need to establish a budget of at least $1000. If you've got that to spend then we can talk further.
Old Mar 17, 2012 | 07:46 PM
guppymech's Avatar
Read this thread for an alternate view on things:
http://www.ls1lt1.com/forum/lt1-|-lt...am-budget.html
Old Mar 18, 2012 | 08:39 AM
IronOutlaw's Avatar
I've ran the hotcam and it was a very nice little street cam. You could run it with stock rockers and just change to some cheap howards or lt4 springs. Get a mail order tune.
Old Mar 18, 2012 | 09:53 AM
rich5368's Avatar
Here's the thing about tight budgets and working on cars. Take what you think it's going to cost and add a 30-40% buffer just incase for extra parts replacement, stuff you break on accident, etc... Like said above plan to spend around $1000 to do this right. I wouldn't even attempt it unless you've got the funds. Trying to stay within a budget can easily lead to jimmy rigging and poor maintenance.
Old Mar 18, 2012 | 09:23 PM
Luedy239's Avatar
I'm on a tight budget cause i wasn't expecting to be rebuilding my engine. But i was hoping that i could do something to add some power while i had the engine out and apart. If not a cam, any other opinions on cheap/safe upgrades? I was thinking about porting my heads a little bit...stupid idea? I appreciate the help guys
Old Mar 18, 2012 | 10:21 PM
F0x Slaughter's Avatar
I had to do the valves on my car and I wanted to do a cam swap well I didn't have the money so it got put back together stock. Its not that hard to tear it back apart. Specially after you do it a couple times.
Old Mar 18, 2012 | 11:44 PM
englundjd's Avatar
if those are your only 2 options id run the cc305... i got the 304 and its alright. works great to daily drive. its not very noticable at all but that also means there isnt much horsepower to be gained... its a pretty weak cam to be putting in if your going to spend the money on it. If i was you i would look at a cc305 or maybe a cc502 or 503
Old Mar 19, 2012 | 05:29 AM
RamAir95TA's Avatar
Self-porting as a novice usually does more harm than good, not to mention the gains you'd see even if done right would be minimal on the stock cam.
Old Mar 19, 2012 | 06:11 AM
SS RRR's Avatar
Village Troll
I guess it depends on what is considered minimal gains. I picked up 5mph through the traps with done right ported heads. Only thing different was Edelbrock shorties into the stock exhaust with cats in place. I dunno...
Old Mar 19, 2012 | 06:37 AM
RamAir95TA's Avatar
I just don't see ported heads on an otherwise stock engine providing gains proportional to the investment. Meh.
Old Mar 19, 2012 | 06:58 AM
SS RRR's Avatar
Village Troll
IMO it depends on what the person wants. If they want stock behavior, like I did since I was into street racing at the time, it's a fantastic investment. I even bead blasted the powder coating off the LT4 because at the time everyone thought LT4 was like ZR1 is today. Like Uncle Johnny Lingenfelter did, I still believe well ported heads alone will outperform any cam on stock heads.
