Mods?
Old Mar 19, 2012 | 03:24 PM
CAMARO51190's Avatar
Post Mods?
I have a 1995 Z28 Camaro.. (Sry for no pic) But i am looking into modding i my car more idk what should I get nexts?.. i am thinking a good mod to have but not to expensive.The mods i have now is (Below) what would be a good mod to have if anyone can help thanks
Mod:
3.73 gears (tomarrow)
Long tube Hearders
ORY
magnaflow cat back
K&N intake
Electric Cut out
2800 Stall
Shift kit
Ac By pass pully
LT4 Knock sensor
Tune from Mad z28
Old Mar 19, 2012 | 03:58 PM
lethal bird's Avatar
Nitrous....
Old Mar 19, 2012 | 04:16 PM
SR_94Blackbird's Avatar
1.6 or 1.7 Rockers. Then a cam later on.
Old Mar 19, 2012 | 04:18 PM
93 LT1 Vette's Avatar
1.6 roller rockers and new valve springs, if you don't want to crack open the motor. If opening it up is not a concern, then a better cam along with the rollers and springs.
Old Mar 19, 2012 | 04:38 PM
IronOutlaw's Avatar
Sticky tires.
Old Mar 19, 2012 | 05:04 PM
Originally Posted by IronOutlaw
Sticky tires.
Yea that's next on my list nitto 555R I am thinking
Old Mar 19, 2012 | 05:10 PM
555rs suck. If you want a sticky tire try a et street or a Hoosier dr.
Old Mar 19, 2012 | 05:15 PM
IronOutlaw's Avatar
I'm going with 555r on my wheels. Hope to get under a 2.0 60' at the track. I was trapping faster than most of the cars there but was losing with my 2.4 60 time. Lol.
Old Mar 19, 2012 | 05:28 PM
I am not going with roller rockers right now.. i think tonight i am going to do the Throttle body by pass.. idk what else i can do to see a good horse power gain except for heads and cam idk dont want to spend that much.. because i am going to spen about $590 in gear install
Old Mar 19, 2012 | 05:30 PM
yea i heard nothing bad about the Et streets prob going with that
Old Mar 19, 2012 | 05:48 PM
Fastredz28's Avatar
Weight reduction ? have you taken out your heater box and all the a/c stuff??
Old Mar 19, 2012 | 05:53 PM
all the AC yes did that this week... Heater.. No because i live in Ohio considering that we have Horiable weather.. one day its 80 and sunny the nexts day it 30 so i am not going to take out the heater boxs lol
Old Mar 19, 2012 | 06:14 PM
I cut a 2.0 on cheap street tires through a m6 and a completely stock suspension.
Old Mar 19, 2012 | 06:45 PM
FAD2BLK93's Avatar
I was doing 1.94 on the brake and leaving the line up on the stock converter at about 1400 rpm, brakes would hold it no more than that.
Old Mar 19, 2012 | 06:49 PM
IronOutlaw's Avatar
I need the driver mod. It was my second time to the track with the M6, the first trip I got in one run. Im hoping with the Nittos the will make up the difference of my shitty driving.
Old Mar 19, 2012 | 07:16 PM
You've covered most of the cheaper mods. Only cheap boltons left, are underdrive pulley, TB bypass, MSD coil, and airfoil they may only net you 5 to 8 hp. Without getting in the motor your about maxed out.
Gears, stall and shift kit were good mods now you need to build a H/C/I motor.
Old Mar 19, 2012 | 08:20 PM
Personally I would go with some suspension, tire, and nitrous.
Old Mar 19, 2012 | 10:17 PM
F0x Slaughter's Avatar
Rear suspension. Lower Control Arm relocation brackets, Lower Control Arms, Torque Arm, could relocate the battery to the trunk, Nitrous as stated. No need for 1.7 rockers. 1.6 yes.
Old Mar 20, 2012 | 09:15 AM
Does anyone know how much porformance i am going to see after my gear install.. i am going from 2.73 to 3.73.. my buddy said i wont see that much proformance.. and does anyone know how much time i will shave off on 1/4 track?
Old Mar 20, 2012 | 03:56 PM
I dont know 1/4 mile times but a step from 2.73 to a 3.73 is a big difference.
