Teaser pics: 396 LE4 Trickflows/efi connection LS conversion
Old Aug 4, 2012 | 12:18 PM
  #61
slckstr96's Avatar
I'll post a video up later today. No times or hp numbers yet. Still need to get a rearend and some suspension. Gonna rent a local dyno soon to finish the tuning.
Old Aug 4, 2012 | 12:21 PM
  #62
slckstr96's Avatar
Shootin for 10s N/A then hit it with some spray....aimin for that 9 sec time slip!!!
Old Aug 4, 2012 | 12:25 PM
  #63
slckstr96's Avatar
Aimin for mid 400s at the wheels. Got the clear lid from speed inc. Just modified the radiator shroud from bmr to fit the lid, put a thin bead of silicone around the filter to seal it to the lid so no rubber pieces are used, works perfect!
Old Aug 4, 2012 | 06:35 PM
  #64
slckstr96's Avatar
sorry about the shakyness i took the video with my phone
Old Aug 4, 2012 | 06:45 PM
  #65
slckstr96's Avatar
Got the underbody all coated
I run a CNC at work so i made my own gauge plates out of ABS plastic
Ill run a blank plate up top until a get the nitrous gauges!!
Old Aug 4, 2012 | 07:24 PM
  #66
Rob94hawk's Avatar
Awesome! Are you using a 100mm MAF? What headers?
Awating dyno and track results!
Old Aug 4, 2012 | 08:04 PM
  #67
slckstr96's Avatar
No MAF, speed density. using pacesetter long tubes
Old Aug 5, 2012 | 10:51 AM
  #68
BizZzatch350's Avatar
Moderator
Car looks awesome, having that tubular K must make is a breeze to work on from the underside.
Old Aug 5, 2012 | 12:46 PM
  #69
slckstr96's Avatar
Thanks bizzzatch350 ya that k member is awesome definitely makes working on it much easier
Old Aug 6, 2012 | 01:47 PM
  #70
rustykey's Avatar
Sexy! Building a healthy 396 also. Bout to get it to tje shop for the shortblock build. Hope it turns out as nice as yours. What compression ratio you at?
Old Aug 6, 2012 | 03:28 PM
  #71
kylemm1002's Avatar
Want to make another plate like that for the hvac control?
Old Aug 6, 2012 | 07:47 PM
  #72
slckstr96's Avatar
Cool rustykey, good luck with the build, you will love it! I'm right at 12.0:1 compression. kylemm102 I can make a plate for you for $20 if that's cool? That will cover material cost and shipping
Old Aug 6, 2012 | 08:15 PM
  #73
BOLO's Avatar
Awesome build! Who did your initial speed density base tune for the 24x conversion? Again, congrats on the new set up.
Old Aug 6, 2012 | 09:07 PM
  #74
slckstr96's Avatar
My engine builder Ron Derickson did the tune. He's been messin with this stuff for a while. We had no issues with the base tune wither, fired right up and never once tried to stall. Still working on fine tuning, she's gettin closer and closer. Thanks for the praise BOLO!!
