lt1 info needed
lt1 info needed
Hello guys, pretty new to the ltx motor. I am planning a cam swap for my 93 a4 z28 soon and this is my list of parts:
Cc503 cam
1.6 rrs
Alex spring lt1 springs
New msd opti
Pnp on the heads an intake
taylor wires
Mail order tune
My question is do I need different injectors, if so what size brand? Is a 3600 stall overkill? Anythink else I should get or change while I'm there?
Cc503 cam
1.6 rrs
New msd opti
taylor wires
Mail order tune
Cc503 cam
1.6 rrs
New msd opti
taylor wires
Mail order tune
Cc503 cam
1.6 rrs
New msd opti
taylor wires
Mail order tune
I think some folks missed that.
IMO 22lbs injectors and ported heads/cam do not go together.
I would put an MSD cap and rotor on a stock opti NOT buy a complete MSD opti. Put the savings towards injectors.
Also consider your car is 20years old, it might endup needing a fuel pump to feed this. A perfect working order stock pump could likely feed it but again, your car is 20 years old so sometimes we have to change additional things..
96caprice.
Thank you I meant I was going with the full msd opti and does everyone reccomend a gm replacement pump? Any suggestions on injectors size brand?
Thanks paul will defaintly remember that my car has 16x miles on it is it stupid do a cam swap car seems to be well taken care of good oil pressure don't burn oil. Had the heads done bout 20k ago by prevois owner in cali what you guys think?
When you do the cam swap, be sure to match the cam dowel pin length of the 503 to your stock cam dowel pin length by either tapping it in with a mallet or grinding it down. It will cause major problems otherwise.
93formula thank you, I have done a bunch of research on cam swaps an this is one thing I have made tons of notes on to not forget it, all with book marking about 8 sites with cam swap articles. I feel pretty confident. Does anyone know any good lt1 tuners here n oregon?? Idaho possibly??
https://ls1tech.com/forums/northwest-members-66/
