220CNC TEA/Trick Flows :)** Dyno sheet RESULTS**
Nice numbers, but the exhaust numbers are super high...
At .500 lift your heads flow 300/243
Some examples of other popular LTx stuff:
AI CNC TFS at .500 flow 285/196 (AI website)
LE TFS at .500 flow 285/197 (on a recent customer's heads)
AFR 227's with race port at .500 flow 288/208 (my heads)
FWIW my ported AFR 220s @ 227(which were not really ported with mid lift flow in mind) flowed 282/207 @ .500 without a pipe, on a 4.060 bore. Even with a pipe that would be, what, 230cfm? 243 is nuts!
I'm guessing it was either flowed with a pipe or wasnt on a standard Superflow bench.
exactly mine flowed right around the same on a 4.030 bore with no plate and no pipe.....243 seems really inflated.....small ports like the exhuast side ~75-80cc's seem to increase alot when tested on a large bore......regardless they are a great head ive heard alot about TEA.....be curious to see how it runs!!
already sold the lt1's that just came off it
Figured I would give yall a update... Heads are on the car, gotta do some port work to the lt4 intake so everything lines up, header gasket and new injectors should be in tomorrow as well, so hopefully it should be ready to roll by the end of the week. Depending on the tuners schedule
#32
For instance, IIRC the head the OP has was 2Xcfm down on the intake & 4Xcfm down on the exhaust when tested on my SBC LT test setup & flow bench. My bench isn't "low" or "stingy," it is just that flow #'s are for marketing. Buy useless marketing info at your own peril.
#33
Unfortunately, all of that is meaningless since the #'s aren't comparable.
I posted those numbers to show what the popular head porters are getting on their own benches... which shows are far "superior" the TEA heads are on the exhaust side [/sarcasm]. My point was I don't think TEA has some secret porting knowledge that allows them to get numbers like that on the exhaust side if all benches were equal.
#34
In hindsight wouldn't you question the integrity of a company who will go to such lengths to inflate marketing numbers as to "test" on a bore size not even available? I am aware of the GMPP prototypes and Jeff Green's self made Donovan LT1 conversions, but from a realistic standpoint there are no 4.125 bore LT1 blocks to be had.
Besides the already discussed tactics they used to inflate numbers how about the clay radius? Isn't it appropriate to post what the radius was? Otherwise hell it could be a velocity stack.
All that "trickery" sure does pay off though when people send them money because they have inflated numbers rather than honest ones.
#37
Just for ***** and giggles lol, here are the SAME heads, but flowed by Tick Performance on a 4.030 bore and a 28" Bench with a 2.00"x4" stack on the exhaust side. Just to bring them down to another perspective...
http://www.tickperformance.com/produ...4-engines.html
#38
