Spray on an lt1
Old Mar 29, 2012 | 07:36 PM
Blk Btty C5's Avatar
Default Spray on an lt1
Had in mind of buying an lt1 doing some bolt ons and spray, how well do lt1s take spray? Would it be bad with over 100k miles? I would like to know what I need to look out for, any help I would appreciate thanks
Old Mar 29, 2012 | 07:51 PM
bowtienut's Avatar
If the engine has had average maintenance and use over that 100k, it will take a 150 shot for a long long time, provided you never run out of fuel supply and you have the tune right.
Auto trans? It will be the first weak link you'll find. Setting the upper limit of the window switch to cut the spray at the shifts would help it.
I ran a 150 shot on a bolt-on LT1 for several years, ~125 runs. Never hurt a thing. 11.3's in a 4000 lb car.....however if you try to do that with a stock F-body rearend, you'll find another weak link
Old Mar 29, 2012 | 07:54 PM
OutlawZ's Avatar
rearend, tranny, and hyperutectic pistons..... those will generally break first.... provided the car is in good condition tho as said before you should be fine with a 125-150 shot...
I'd definitely upgrade the injectors if you are going to use a dry kit..... plate not so much. but i'd still DEFINITELY upgrade the fuel pump and injectors regardless.... a hot hole and it will break the piston...
Old Mar 29, 2012 | 08:43 PM
onephatZ28's Avatar
just stick with a good brand. If it were me I would run a wet kit. I ran a 150 shoot for years and loved it, with a stock tune. also make sure you go with a good plug
Old Mar 29, 2012 | 09:00 PM
coolmanvette75's Avatar
Nitrous outlet plate kit. Gonna be spraying a 150 shot on mine in a few weeks and I'm at 140k...
Old Mar 29, 2012 | 10:33 PM
1_MEANZ28's Avatar
built the bottom end..but for now it its a 50/50 chance ..it always is
Old Mar 30, 2012 | 12:21 AM
turtle93's Avatar
116 miles on mine spray 100 shot the zex noid went be for my motor lol
Old Mar 30, 2012 | 06:01 AM
bowtienut's Avatar
Could you put that in English please. Honestly, I have no idea what you just tried to say.
Old Mar 30, 2012 | 06:55 AM
He said the zex noid gave way before the motor did...
Old Mar 30, 2012 | 07:41 AM
bowtienut's Avatar
Thank you! Maybe I'm just too old to be in these threads
Old Mar 31, 2012 | 06:46 PM
turtle93's Avatar
Nope I just have horiable grammar I'm sorry
Old Apr 2, 2012 | 10:41 AM
69gto96z's Avatar
I had 130k on my motor, put 15-20 bottles of 150 shots through it with a Walbro 255, no problems ever.
Old Apr 2, 2012 | 12:31 PM
itSSlowZ28's Avatar
Several people have run 200 shots on stock short-blocks. Just don't skimp out on the stuff to make it safe
