Running rich...really rich...
Old Apr 3, 2012 | 08:12 PM
GreenBlood55's Avatar
Default Running rich...really rich...
Ok, I am getting very good gas mileage, car runs smooth for the most part. However.... its running pig rich. My clothes always smell like gas/exhaust.. I drove in front of a friend the other day for 1/2 mile and when we stopped he said he could smell gas/strong exhaust fumes... Also on cold start ups I get some minor popping/backfire a few times but quickly goes away.
Car has new plugs and wires and opti. Again, it runs great. No misses or anything.
My MAF is desreaned. This was done before i got the car. I did have the car started and running, and unplugged the MAF. The car did not do anything different at all. The check engine light came on, but when i plugged it back in, the light went off. Im not throwing any codes and dont have a current check engine light.
Does this sound like a obvious MAF issue, or 02 sensor issue, or????
Old Apr 3, 2012 | 08:16 PM
RamAir95TA's Avatar
Datalog the car and/or put a wideband on it. Smelling is a very inaccurate way of determining rich or lean.
You say you aren't throwing any codes, but you'll want to scan it anyway, since not all codes set the SES light.
Old Apr 3, 2012 | 08:17 PM
Twin_Turbo's Avatar
What are the long and short term fuel trims or each O2 sensor/bank???? I was fighting a similar issues, it turned out to be the multec injectors, replaced them...improved quite a bit.
Old Apr 3, 2012 | 08:22 PM
ugghh.. i have no scanning skills whatsoever, and when i tried finding someone local to scan it, i had NO luck. it seems like no one around here scans OBD1 cars anymore.
Old Apr 3, 2012 | 08:28 PM
RamAir95TA's Avatar
Because of the shift from OBDI to OBDII in the mid 90s and since an OBDI PCM hasn't been produced since 1995 I would expect OBDI scanners to eventually become obsolete and only available at dealers and such. In this day and age if you're going to own an OBDI vehicle and work on it yourself regularly you need to acquire a laptop, cable, and software to do it yourself or else you're just going to go around in circles like you likely are. With how cheap (and free) it is to acquire such a setup it just makes sense.
Old Apr 3, 2012 | 08:45 PM
ramair, was that a offer to check it out for me? bwaahahahaha
no really, was it?
Old Apr 4, 2012 | 04:18 AM
Twin_Turbo's Avatar
A red brick scanner will do both and more, those things will not go obsolete in a long time.
Old Apr 4, 2012 | 06:28 AM
RamAir95TA's Avatar
I understand that, but for the home backyard mechanic, a $50 cable and a laptop computer can far outperform the small box units anyway you cut it.
Old Apr 4, 2012 | 03:49 PM
1_MEANZ28's Avatar
mines curently runnig rich gas is killing me ..lol
previous owner told me when the car got tuned it came a lil rich on one side.but he left it that way for the nitrous better safe than sorry
Old Apr 4, 2012 | 07:37 PM
Rob94hawk's Avatar
where's this $50 cable you speak of? I'm getting $80:
http://www.moates.net/aldu1-and-cabl....html?cPath=64
Old Apr 4, 2012 | 07:39 PM
RamAir95TA's Avatar
http://www.aldlcable.com/
Sorry, $60 now!
Old Apr 4, 2012 | 07:51 PM
blackthunder50's Avatar
Don't want to steal your thread but I have the same problem. I didn't experience any issues until I took the catalytic converters out and swapped in the custom y-pipe. It smells just like my Pop's 65 corvette. I think its just the nature of running a catless exhaust system.
Old Apr 4, 2012 | 08:05 PM
Rob94hawk's Avatar
Thanx! That's better then $80. Just ordered it.
Now which program for data logging and interpreting it?
Old Apr 4, 2012 | 08:34 PM
But I have a cat... unless it for some reason is not doing its job, but if that was the case wouldnt I have the typical clogged cat symptoms?
Old Apr 4, 2012 | 08:35 PM
And, no one commented on my MAF not making any kind of difference at all when I unplug it other then turning the SES light on. Car doesnt sputter/bog/stall nothing. runs exactly the same plugged in, or unplugged.
Old Apr 4, 2012 | 09:06 PM
WS Sick's Avatar
Hopefully that means the VE tables are dead on....
I personnally use Datamaster, it may cost after youre free 20 logs, but it is really worth it. You'll need a laptop and a cable with it as well.
Old Apr 6, 2012 | 08:46 AM
stdjsw311's Avatar
Having the same prob. My gf won't even ride in the car with me! I have changed the o2 sensors and it didn't make any difference.
