Car is missing - logs and pics - SOLVED!
I took a data master log:
http://www.cdntechnologies.com/camaro/1994M6LT1.zip
And pulled the plugs:
http://www.cdntechnologies.com/camaro/plugs/
Is that oil or gas on the threads?
What's next? Any help greatly appreciated!
Holy ****, throwing codes like crazy.
13.5 degrees of spark retard.
What in the hell did you do to this car?
Your running so lean on the right bank bank I bet you fried the valves for starters.
AFR heads, big valves, CC306 cam, monoblade TB.
No cats egr iac or air pump, modern muscelcar tune.
It was running great for a few years. Then I stored it for a looooong time. Drove it about 20 miles since I took it out of storage trying to find the miss. Bad gas has blown through I think it's only on good gas now. I'm trying to find out what's wrong and don't know my next steps. I will check plug wires now and see if any are cracked/melted.
How do I tune out the EGR? I have the aldl cable and can get tunercats or whatever I need. So far all I have is that datamaster log I took yesterday to help me figure out what to change or replace to get it running good again. It can do 11's when running right. Right now it's a mess from storage and I don't know where to start.
Thank you,
Jason
The plugs on passenger are black
On drivers white
Thanks
You just tune it out by tuning the PCM.
Passenger side is the right bank. Which your o2 says is running extremely lean. So what you could do is fire it up quickly and hold a screwdriver to each injector harness and you should feel it click, hold it to your ear if you have to. This means the injectors are firing.
A spark plug should be tannish. Pure white on it means its burning water (head gasket leak).
Look at your coolant, if its a milkshake or has oil in, head gasket.
In TunerCat go to Tables > ECM Switch > Uncheck EGR Diagnose Error 32, EGR electric failure Error 27. It won't set off the codes anymore.
Whats the fuel pressure look like?
I have a compression tester I will do that and leak down after changing the oil.
If passenger is right bank, is that the one reporting crazy lean from the Datamaster log? Why are the plugs on that side all fowled black? I thought lean would be really light coloured plugs not black? The almost normal looking plugs in my pic are from the drivers side, the really dark plugs are from the passenger side.
I did the listen to injector test before pulling the plugs; all injectors were ticking.
I will look at my coolant. Thank you.
I went WOT a couple times logging; hope I didn't actually fry anything it's an expensive setup I have a totally built bottom, splayed 4 bolt etc, AFR heads, etc.
I pulled the wires and tested them, they are MSD 8.5 and reading between 80 and 170 ohms, no cracks or burns.
Ok so my list is now
1) check coolant
2) ?
Thank you everyone, it's been a decade since I worked on these things.
A compression test will tell you if you have shot the rings, or valves. Leak down test will tell you whats shot, if you hear it in the
Oil: Rings
Intake: Intake valve
Exhaust: Exhaust valve
Coolant: Head gasket
You will usually hear an exhaust leak as its sucking air in.
Oil: Rings
Thank you,
Jason
If it doesn't build compression or bleeds off compression you have some problems then its time to go to the leak down test and see what is fried.
Remember to pull the plug wires off so it can't start when doing the compression test. Just pull all the wires, hook up compression test, bump the starter for about 2 - 3 seconds then stop, check gauge. Also if you squirt about a cap full out oil into the cylinder and the compression bumps up, rings are bad.
There could be many reasons why its lean on the one side. Sitting for so long can plug up the injectors and not spray properly. May need a good cleaning. If its still running lean on the one side it could be a bag regulator.
The plenum was full of wet and fuel smells when I popped the TB off yesterday.
Question: My right 02 is reading under 10mv if you look - maybe this is all just a bad 02? Did anyone else notice that from my log? The right bank is also the bank that is dumping fuel at 160
I will check the fuel pressure and that vac line, seems like everyone is saying to check fuel pressure so I better do it.
Since the plugs are our I will to a comp test to see if it's washed or still sealing.
Then I will put fresh plugs, put the good wires back, fresh 02, and take it from there.
