nitrous question
Old Apr 15, 2012 | 07:46 AM
ALEXZ28's Avatar
Default nitrous question
i just bought a trans am, its got 220k miles. i wanna spary a 75 shot on it. does miles matter when it comes to nitrous ????
Old Apr 15, 2012 | 07:57 AM
Luke1996ta's Avatar
I would think spraying had its concerns at any type of miles
Old Apr 15, 2012 | 08:16 AM
ALEXZ28's Avatar
good point, i know alot of people that have been using nitrous for years on stock cars and there still running today. just didnt know if the 220k would make a difference.
Old Apr 15, 2012 | 08:42 AM
96lt1m6's Avatar
75 shot is fine I would not think twice about spraying it...
Old Apr 15, 2012 | 02:32 PM
WhitePhoenix99's Avatar
Assuming the engine is running properly mechanically, throw some colder plugs in and have at it
Old Apr 15, 2012 | 03:21 PM
F0x Slaughter's Avatar
Run a compression check. If compression checks out you could even spray it with a 150 shot.
Old Apr 15, 2012 | 03:35 PM
robsquikz28's Avatar
Lol it will help seal the rings. If it was me I would blast a 150 shot through it.
Old Apr 15, 2012 | 03:40 PM
What help seat the rings into the oil pan? Rofl.
Old Apr 15, 2012 | 05:11 PM
Lol nope...I had 232k on a camaro I picked up and had 150 shot for over 50 passes and ran 11.6s all day. It finally blew up after I had about 20 200 shots on it.
Old Apr 15, 2012 | 08:04 PM
OutlawZ's Avatar
do they even make 75hp jets???? LOL....
Been awhile since I dealt with any jet's smaller than huge....
i'd say compression check and let loose with an even hundo shot.... i wouldn't be doing it all day everyday tho. unless you like blown motors....
when my stock motor let go it punched a rod THROUGH the cylinder wall, shattered the piston into 9 million pieces. I drained the oil and 4 gallons of coolant poured out.. :-O
Old Apr 16, 2012 | 08:03 AM
soco80p's Avatar
With such a light shot you shouldn't have any problems.
Old Apr 16, 2012 | 03:32 PM
Konman93's Avatar
I would uses a set of good plugs. I use NGK-tr6 and never had a problem with them. What about you guys?
