Is a tune needed when doing a stall converter??
Thanks
I always have to thank Ed Wright for digging into the code and finding the real fix for us
When I went back to OBD2, I also deselected the VSS error options and have had no problem even with the hard hitting 8" TC.
Edit 1/5/13: The fix is NOT the VSS error code. Moving the WOT mph threshold for the 1-2 shift down to 1 mph and letting it shift on the rpm trigger was the fix for mine.
Mine was the 1-2 no-shift as soon as I went from a Yank 3000 to an Edge 3400 behind the stock engine.
I see above you were talking about default to 3rd gear. Mine never did that.
Our first fix was to use a OBD-II PCM.
I think I shut it off and restarted it after I cruised down the track on that pass, so I never even noticed if it defaulted to 3rd gear only.
