Looking for info on Eagles 3.25 stroke 1 piece crank.
I picked up a 92 LT1 4 bolt block several months ago, that has been cleaned and magnafluxed for cracks. Bore is STD and will clean up at .010. I was looking for info on Eagle's forged 3.25 stroke 1 piece crank. My plan would be build a high winding 327 4 bolt with forged internals, AI 200cc heads on a big shot of juice for my Vette. Any help or opinions on parts? Cam size, compression ratio **** like that. I've got a set of old school .030 Forged TRW flattops on forged pink rods with ARP bolts but their not I or H beams.
I also plan on stepping up to 3600 stall and 3.73 gears. The Vette currently tips the scales at 3080 pounds so Tq isn't my major concern. Just thinking about doing something a little different.
Thanks Brian
Thanks Brian
Mechanically no reason, other than the 3.25 stroke and forging instead of cast. But right now I'm on a stock bottom end running 125 to 150 shot to run with Pullied Cobra's, Gen 5 Camaros and bolt on C5's. Plus over the past several mornings, I'm hearing what I think is some piston slap or rattle in the lower end. Oil pressure has not changed or the water temp but I think it is the beginning of the end. I would like to build something that can handle a fair amount of nitrous, good strong running and be a little different.
I know alot of buddies gave me a tough time when I built a destroked 400 for my Nova and they were right. The 377 spun a crank spacer and bearing less than 6 monthes after being built.
I'm just looking for a forged bottom end and because I've got some **** like those 327 TRW's in the garage it seemed like a good idea.
The stock crank can not be considered the same as the aftermarket cast cranks.
I an not aware of anyone overpowering or over reving a stock crank, just use the stocker and if you really want to wind it high put what we save you on the crank purchase towards a computer system upgrade. I believe the 93 system will turn higher than the 94+ systems but comes with other drawbacks.
In the 60s and 70s metallurgy and manufacturing were not what they were in the 90s, way back then they destroked stuff to keep things in one piece. These days it is not necessary.
P.S. The Trans-am series had a 5 liter displacement cap, which is why the Z/28 was a 302 and Ford had a BOSS 302.
Seems destroking is as popular now in 2012 as it was back 20 years ago. LOL So just run a stock crank and rods with some good forged pistons and balance the rotating assembly is what I'm getting.
Class rules certainly did cause destroking but many old timers I have talked to over the years liked the shorter strokes because they broke too many cranks with the longer strokes even just on the street.
If you don't have to meet class rules and the a stock stroke is reliable to the rpm you want/need why spend money for less displacement.
I don't think displacement is the key to power but at the same time I don't see any point in spending extra to reduce it without some specific reason like class racing.
A 327 with AI's 200cc heads, good cam, and the rpms you would want to spin it to would be well over the rpm limits of the computer... add nitrous and you have made the limitations of the stock computer look even more foolish.
1 sell the pistons...
2 buy a decent set of rods/pistons for the stock crank.
3 Add a great set of heads (AI/LE/equivalent)
4 make a smart cam choice
5 add all the nitrous you can run through your particular set of heads
6 have lots of fun
7 plan on replacing everything else......lol
6 have lots of fun
