Performance ICM?
Old Apr 22, 2012 | 08:12 PM
Driftunit's Avatar
Default Performance ICM?
Is there a performance ignition control module for lt1 cars? i believe mine is going bad or has went bad and if its possible to upgrade, id like to. Ive tried some looking around and cant seem to find much other than people trying to figure out whats wrong with theirs. I have upgraded most of my ignition system and would hate to leave this little guy behind.
Thanks, Kegan
Old Apr 22, 2012 | 08:23 PM
F0x Slaughter's Avatar
Pretty sure there isn't a "performance" ICM.
All the ICM does is tell the coil when to fire.
Old Apr 22, 2012 | 08:31 PM
Driftunit's Avatar
lol oh, well just checking. explains why i couldnt find one then. looks like ill just go with something from an auto parts store, thanks.
Now they do make "performance" coils that put out a higher voltage with each firing.
Old Apr 22, 2012 | 08:35 PM
RamAir95TA's Avatar
Refrain from using an auto parts store ICM and go with AC Delco.
Old Apr 22, 2012 | 08:37 PM
^ What he said.
I try to stick to AC Delco stuff. You will obviously pay more but it will last.
Old Apr 22, 2012 | 08:47 PM
Driftunit's Avatar
AC Delco it is then. i have an msd coil on the car along with msd wires and a 6al box and fresh plugs already. im still running a stock style opti that im sure will go at anytime so im going to run the hell out of it till it does. An msd opti will be in the works soon even if my current opti survives the abuse. the peace of mind will be worth the money, esp when running a multispark setup.
Old Apr 22, 2012 | 08:49 PM
I bought my car with an MSD opti that was replaced like 5000 miles before I got it. Test drove the car 3 times before buying. Got home, next day the car wouldn't start. Replaced the Opti with a AC Delco and has worked ever since. That was over 10000 miles ago.
Old Apr 22, 2012 | 08:55 PM
Driftunit's Avatar
interesting, on the msd site they have all this big talk of it being an upgraded more reliable piece compared to the factory design so i dont understand why people have bad luck with them. but then again is it possible you got the best end of one brand and the worst of the other? im sure in some cases its the other way around. there is a pretty wide price gap in the 2 also, that may end up being my deciding factor lol
Old Apr 22, 2012 | 09:01 PM
I just run a AC Delco before its factory equipment. MSD might work great for some people. I've heard people say the Chandler Motorsports works great. I tried it because of the price and it didn't work. Got the AC Delco and fired right up.
So to each his own.
Old Apr 22, 2012 | 09:23 PM
popo8's Avatar
Originally Posted by ramair95ta
refrain from using an auto parts store icm and go with ac delco.
this^^^
Old Apr 22, 2012 | 09:24 PM
Driftunit's Avatar
Agreed. im just dreading that dent in the wallet plus the install isnt pleasant from what ive seen and heard so im gonna have a shop do it because id rather not mess with getting a distributor dialed in. itll be the first time ive had to take it to a shop for a mod thus far so itll be kinda saddening lol. then ill have to start saying ive done "almost" all the work myself lol
Old Apr 22, 2012 | 09:40 PM
Um read the instructions all you do is put the pin in the correct hole for the vented models and bolt it in. Simple. They will probably charge you hundreds for doing it. Cause a lot of the front of the engine needs to come off.
Old Apr 22, 2012 | 10:04 PM
Driftunit's Avatar
really? you dont have to adjust it or anything? cause if it just slips in and bolts right up i dont care to tackle it. Thus far ive rebuilt, repaired and installed headers, made my own Y pipe, wired up my ignition box, trouble shooted and fixed at least 4 different missfire problems and all that was jobs i was a little intimidated by but came out great in the end. if replacing the opti is that straight forward then bring it on. and yes ive seen all the junk in front of it, i can understand why it would be a pain to replace as far as that goes
Old Apr 22, 2012 | 10:07 PM
Nope it can install the wrong way if you slip the cam dowel into the wrong spot. But all you do is align the optispark with the dowel in the correct hole and bolt it on. Done.
Old Apr 22, 2012 | 10:11 PM
Driftunit's Avatar
Well hell, look at that! ask a question, get an answer! thats why i love this site. looks like ill add it to the to do list then. worse case i can drag a mechanic over to my garage. anyways though, thanks for the help and the advice ill keep it all in mind. AC Delco icm and tackle the opti, Got it thanks!
