Hydraulic roller adjustment question
That's almost .025" on a 7/16" stud (~.021 on 3/8).
Aftermarket recommendations vary from vendor to vendor.
Most of the engine builders that I talked to said 1/16 - 1/8 (For reference; 1/12th is rotating from a point to a flat)
Read this until you feel comfortable, then read it one more time.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
It can cause it to bang at high RPM, lay over at high RPM, etc.
1/16th -1/8th turn on mine. 7000-7100 shift points.
A LOT of references say "spin the pushrod till you feel resistance" and that will nearly always endup being way past zero lash.
Far as what I have run I have run everything from 1/8-5/8 and couldn't tell a difference but I had use good valvetrain.
As said super low preload is about minimizing valve bounce when the valvetrain is on the ragged edge of control or beginning to lose control. I understand the idea behind a lot of preload like wicked94Z is saying but never tried it.
If you just go 1/8-1/2 a turn it is simple, no worries. "just set it and forget it"
As long as meticulous attention is paid to spring pressures there should be no problem running stock lifters at minimal lash.
You reach this point when all of the slack is removed, not when you've squeezed so hard that there is friction between lubricated parts.
