Ticking from Injectors
Old Apr 29, 2012 | 08:47 PM
OnA Fan's Avatar
Default Ticking from Injectors
I think I found the source of the ticking under the hood. Looks like it's coming from the injectors. What would be the cause? Did they all go bad, or is there a low/high voltage/amperage issue? Other then the tick, the car idles and revs just fine.
Old Apr 29, 2012 | 09:12 PM
F0x Slaughter's Avatar
I highly doubt the ticking is from the injectors. Injectors will click when they fire. You can verify this with a stethoscope or a screwdriver against the connector. Ticking will most likely be exhaust leak, spark plug wire arching, bad lifter thats not pumping up.
Old Apr 29, 2012 | 09:37 PM
OnA Fan's Avatar
I did use the a screwdriver to listen for the tick. Only ticking I hear is from the intake right by the injectors, and on the injectors themselves.
Old Apr 29, 2012 | 09:48 PM
warriorcustoms's Avatar
Stock LT1 injectors arent usually that loud But some aftermarket injectors are loud
Old Apr 29, 2012 | 09:50 PM
How many miles?
Old Apr 29, 2012 | 09:52 PM
OnA Fan's Avatar
Old Apr 29, 2012 | 09:56 PM
I'm gonna say you got a lifter ticking.
Old Apr 30, 2012 | 06:33 AM
shbox's Avatar
All injectors tick somewhat. It's what they do. You should get about the same noise from all of them.
Old Apr 30, 2012 | 08:09 AM
96TransAmboosted's Avatar
My injectors have always had a tick, and when you rev it up the sound chanves with rpm. This is normal.
Old Apr 30, 2012 | 08:52 AM
OnA Fan's Avatar
I guess the reason for my concern is that the tick in the Pontiac is much louder then what I have in the Buick.
Old Apr 30, 2012 | 09:33 AM
93M6Formula's Avatar
Mine tick pretty loud but it's of no concern to me, car runs just fine.
Old Apr 30, 2012 | 10:36 AM
You can hear them clicking over the engine running?
Old Apr 30, 2012 | 10:49 AM
sweetbmxrider's Avatar
That is the solenoid working bro....
Old Apr 30, 2012 | 07:21 PM
OnA Fan's Avatar
Yes
I realize that, but they are much louder then the injectors in my other LT1.
Old Apr 30, 2012 | 07:28 PM
Rodinator1234's Avatar
My old multitec's were loud, I upgraded to 32lb bosh gen 3's way quieter. I had two that were going bad knew do to resistance check. I know it's possible to here them fire over the engine unless you have open headders.
