Potential future C4 owner, Please Help :)
I got my '93 down to 3150 race weight. Shoot, the res. and the mufflers with the pipes in between weigh 60lbs. The cats come in at 15lb a piece and it's 14.5lbs for each manifold. You can shed weight fast. I also scraped the steel sawblades for some polished aluminum ZR1s and saved 7.5 pounds per wheel.
The vette is like sitting in a capsule. Everything is wrapped around you. Kinda gives off a closterfobic vibe sometimes.
That is a **** load of torque you put down. You still on stock rear suspension?
