T400 guys here
Old May 22, 2012 | 06:36 PM
tricked94camaro's Avatar
Default T400 guys here
Thinking about putting a turbo400 in my '94. what would i all need to make it work besides the obvious trans mount, driveshaft, and torque arm? will my stock starter work?
Old May 22, 2012 | 07:53 PM
RamAir95TA's Avatar
http://www.streetlethal.net/trans/
Stock starter will work.
Old May 23, 2012 | 06:50 AM
Thanks. Seems pretty straightforward. I assume you have one? How do you like it on the street?
Posted from LS1Tech.com App for Android
Old May 23, 2012 | 06:52 AM
Where did you get your parts from?
Old May 23, 2012 | 07:37 AM
RamAir95TA's Avatar
I actually have a 4L60E (in signature), so I can't comment on the 400 on the street. I will, however, mention that I LOVE having my OD. Nothing like having a bulletproof OD trans.
Old May 23, 2012 | 10:07 AM
BIGCAT7274's Avatar
If you want the speedo to work you will need to pick up a reluctor and a pick up. You will need to tweak your cooler lines or make new ones. Are you going to put a shield on it?
Old May 23, 2012 | 10:13 AM
Puck's Avatar
What are you building that you want a TH400?
A 4l60 can hold a ton of power when built right, plus the OD makes it easy to cruise in without screaming down the highway at high RPMs.
Old May 23, 2012 | 10:31 PM
Not building anything special. I dont even have a 4l60e and cant find one for under $400. The th400 is a freebie
Old May 23, 2012 | 10:40 PM
StraightTimeStirrups's Avatar
I actually just did the swap but havnt driven the car yet still more work to do. You will need the correct Flex Plate, Torque Converter, Cooler lines, Dip Stick Tube, Driveshaft Length adjusted, Tranny Crossmember, TA Mount, Shifter.
The swap is super easy to do! I havent monkeyed with the Speedo stuff yet but I did install a Gear Vendors Overdrive unit! My TH400 has a Trans Brake and RMVB too!
Joe
Old May 23, 2012 | 10:45 PM
gregrob's Avatar
An M6 cross member works just fine...
