Is the coolant pipe on back of heads necessary
Old May 23, 2012 | 10:41 PM
cruiser78's Avatar
Default Is the coolant pipe on back of heads necessary
I am putting together a new motor I bought to replace my old one and transferring my accessories and stuff over as I only got just the block and heads with the new motor and on the back of the heads where the coolant crossover pipe goes, the holes are blocked off with plugs that are in there really tight. I snapped off a 3/8" to 1/4" adapter in the one (after pulling out a broken end of an adapter that was in their when I bought the motor) so it's pretty tight. I have eliminated the coolant going through the throttle body a long time ago and I believe that is all this coolant line seems to be there for so if I don't put it back on the new motor am I going to be ok or is it going to be bad for the motor? Obviously I'll have to seal off the rad where the hose that connects to this pipe went in but if I can eliminate some more clutter in my engine bay I would be happy... as well as not have to deal with those tight plugs.
Old May 23, 2012 | 10:54 PM
gregrob's Avatar
Yes..
Old May 23, 2012 | 11:00 PM
cruiser78's Avatar
Originally Posted by gregrob
Yes..
I'm guessing you mean "Yes it's necessary"? Thanks for the quick reply. That's also what I'm finding from searching the net too... o well.. guess I'll have to fight with those tight plugs.
Old May 23, 2012 | 11:32 PM
coreylt1's Avatar
get a punch and a hammer and hit the center of the plug a few times with a few solid swings..nothing crazy enough to break anything. it should come right out. little trick i learned working in a machine shop
Old May 23, 2012 | 11:40 PM
cruiser78's Avatar
Thanks for the tip, I'll give that a try.
Old May 24, 2012 | 06:54 AM
97Z28SS's Avatar
Yes the crossover is necessary otherwise the engine "WILL Overheat" and blow the head gaskets. And if you can't find a stock on you can use AN lines and fittings, that's what I did, plus it just looks better to me.
Old May 24, 2012 | 07:04 AM
shbox's Avatar
Are you sure the heads were not put on the opposite sides and the open holes are now in the front, instead of the back?
Old May 24, 2012 | 11:06 AM
cruiser78's Avatar
No, I'm not sure. The front of the heads also have plugs in each if the holes. Does it matter functionally which way the heads go on? The plugs at the back are extremely tight. My 1/4" drive ratchet is twisting. I tried the punch trick and that didn't do it. Any other suggestions?
Old May 24, 2012 | 11:16 AM
whytryz28's Avatar
Doesn't matter what way as long as the rear of the heads have the coolant crossover tube and the fronts are plugged.
Old May 24, 2012 | 11:29 AM
cruiser78's Avatar
That's what I thought. Not sure how I'm going to get those stubborn plugs out. I read of a few people running without that line and one person mentioned that if the car runs cool, it's not as likely to be a problem. My car barely barely gets above the first line on the coolant temp gauge with the computer time I have. I would still like to get that line on there but I'm almost ready to take my chances on it. :S
Old May 24, 2012 | 01:06 PM
RamAir95TA's Avatar
Perhaps you should read about WHY it's there (specifically how it works) and not go blindly hoping that running without it will be alright.
Keep working at getting the plugs out.
Old May 24, 2012 | 01:18 PM
wrd1972's Avatar
Yes its required and for the reasons for preventing overheating and hot spots like what others here said. If it were not required, GM would not have wasted the X amount of dollars to outfit every LT1 with it. Folks who dont run it just have not encountered the perfect storm of conditions to casue a the failure, yet.
Old May 24, 2012 | 01:39 PM
cruiser78's Avatar
I do know now after doing some reading up on it why they are there and that's why I said I was almost ready to take my chances on it. I really don't want to though and if I can't get anything else to work I will probably carefully drill them out and then retap them if necessary as a last resort.
thanks for all the replies so far. I do appreciate the help and keeping me on the right path.
Old May 24, 2012 | 01:40 PM
WS Sick's Avatar
Without it, steam cannot escape the heads.
Old May 24, 2012 | 01:52 PM
guppymech's Avatar
Try heating up the heads in the area of the plugs. The aluminum will expand more than the plugs and they should loosen up. Also while the head is hot if you have some parrafin wax touch it to the plugs and it will wick into the threads and act as a lubricant.
Old May 24, 2012 | 02:23 PM
wrd1972's Avatar
Old May 25, 2012 | 08:37 AM
warriorcustoms's Avatar
An Impact Driver is your friend LoL You need the coolant tube just like a 400 sbc needs the steam holes drilled in the heads Its for steam to escape
Old May 25, 2012 | 09:19 AM
cruiser78's Avatar
I'm a little leery of using an impact gun with a 1/4" drive adapter that isn't an impact adapter. I already snapped one and it didn't take much to do it. I may try that though.
Old May 25, 2012 | 09:23 AM
TypeSL2's Avatar
Impact Driver is different than an impact gun. Think screwdriver, but you hit it with a hammer and it twists when you hit it. Google it for a better description.
James
Old May 25, 2012 | 09:35 AM
cruiser78's Avatar
Oh right, I do have one of those too. Never even thought about trying that. Thanks.
