Could this be my problem?? help
Old May 25, 2012 | 11:21 AM
ZzTeaRs's Avatar
Question Could this be my problem?? help
well the car has been having problems shifting at WOT. the check engine light would come on after about 10 mins of driving then turn off when i stopped the car. the previous owner told me that it was for a 02 senser that he removed from the exhaust. well i took it to autozone and had it read since i dont have one. 3 things came up
12- no tach signal to computer
14- engine temp sensor
and 36- which was a 24x signal error
well the car has been having problems shifting at WOT. and i was about to replace the trans. but would one of those 3 things give me problems at WOT? i imagine the tach signal would but im not sure about the 24x signal error any help is appreciated
Old May 25, 2012 | 12:16 PM
ZzTeaRs's Avatar
Also any help with the tacht signal to the computer would really be appreciated I'm trying to Google it on my phone haha. This is my first little build so I'm trying to soak up as many things as I can. Sorry if the questions are kinda dumb
Old May 25, 2012 | 12:37 PM
BlackBird87's Avatar
no tach signal is why its not shifting and the temp sensor needs to be changed asap as well. Thats the one located in the waterpump
Old May 25, 2012 | 12:44 PM
ZzTeaRs's Avatar
Any idea on how to go about troubleshooting the tach signal? Or out the other code??
Old May 25, 2012 | 01:17 PM
I dont know enough about the tach signals to be any help, someone else that does will chime in soom im sure. That last code is an opti high res fault
Old May 25, 2012 | 01:52 PM
ZzTeaRs's Avatar
ok thanks for the help my friend
Old May 25, 2012 | 01:55 PM
WS Sick's Avatar
I do beleive the tack signal code is because the engine wasnot running when they scanned it, right?
Old May 25, 2012 | 02:05 PM
ZzTeaRs's Avatar
nope it wasnt running when he scanned it, the car was turned off but the key was on
Old May 25, 2012 | 05:56 PM
ZzTeaRs's Avatar
Anyone know about the tach signal error ??? If it will send the code if engine is off?? That code got my hopes up as a fix for my problem
Old May 26, 2012 | 09:52 AM
ZzTeaRs's Avatar
Also the 24x Signal is the crank sensor right?? It should be on the top of the heads ?? Sorry I don't have a haynes book I'm going off of the internet and this site
Old May 26, 2012 | 10:25 AM
DisasterFormula's Avatar
Crank Pos. Sensor is on the timing cover at about 7 o'clock to the crank pulley.
Old May 26, 2012 | 10:45 AM
ZzTeaRs's Avatar
Thank you sir
