I'm trying to make it to the shootout... (2013, lol!)
#84
Engine is a 10.25:1 383, AFR 210 heads, big solid roller cam. Should make 4 digits when its done.
#86
Moser M9, narrowed 3 inches per side, back brace and adjustable LCA brackets, 40 spline gundrilled axles, Moser aluminum center section with HD aluminum pinion support, steel spool and 4.10 gear. Will be adding Strange brakes and a custom heavy duty anti-roll bar.
#93
LS1TECH Sponsor
Car is looking good!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
#100
Got the converter back from Micke this week and decided to run a little Outlaw 8.5 race here locally last night. Ended up qualifying 6th out of 10 cars. Lost 1st round to a turbo Fox that had a perfect reaction time (he still would have beat me to the stripe, he had been running over 10mph faster than me!).
First pass off the trailer, leaving a bit conservative, 3000 rpm on the 2 step. I short shifted high gear, but it went right down broadway to my first ever 5-second 1/8th mile pass.
For my second pass I decided to add 500 rpm to the leave, and made sure not to short shift high gear. Then about 500 ft out the car in the other lane looked to have something fly off of it and it distracted me. I lifted a hair early. It would have definitely been a .77 or .78 at probably 125 mph by looking at the datalog.
My third pass was first round of eliminations. I think I was lined up a hair out of the groove, and the car was moving out really good. I was really having to drive it, as it was all over the track. Had to roll out of the throttle a couple times even. Still went almost 124 mph. Still extremely happy for only having a few passes on this combo!
Here's a shot I got after I was all packed up ready to go home.
