odometer swap
Old 06-27-2012 | 10:50 PM
esoteric18's Avatar
Default odometer swap
For my swap I need to install a v8 cluster. Is it possible to swap the odo so I can keep the mileage original?
Old 06-28-2012 | 08:55 AM
esoteric18's Avatar
Bump!
Old 06-28-2012 | 10:47 AM
Fazz73jr's Avatar
Need more info. Swaping to an ls1 dash, v6 to v8 swap, ...?
Old 06-28-2012 | 11:55 AM
esoteric18's Avatar
V6 to Lt1
Old 06-28-2012 | 12:05 PM
esoteric18's Avatar
Same dash. I know the cluster I ordered is fine with my dash but its 2k less miles then my car actually has so I am just wondering if its possible just to remove to odometer from the back and put my v6 one in. As far as I know the only difference is the tach and mph
Old 06-28-2012 | 12:07 PM
Fazz73jr's Avatar
I know on the 94-96 camaro cluster they swap right out... Not sure of that will help since there still no info on what car.
Old 06-28-2012 | 01:45 PM
defaultexistence's Avatar
Personally I wouldn't worry about it.. 2k less means u gained 2k less.. In the end if u sell it will be close enough..
Old 06-28-2012 | 02:08 PM
esoteric18's Avatar
It's a 96 firebird. And I'm not worried about selling it. Just something that's gna bug me lol
Old 06-28-2012 | 03:56 PM
Spartan7's Avatar
The mechanical odometer should swap right over. 97's are a different story though.
Old 06-28-2012 | 07:20 PM
LT1's Avatar
LT1
Not that it matters but, heard its illegal to modifie odometer.
Old 06-28-2012 | 07:40 PM
esoteric18's Avatar
Which is why I am not. Just switching to keep the original miles. Which is more then the replacement has.
Old 06-28-2012 | 09:35 PM
96lt1m6's Avatar
Its NOT illegal to modify an odometer to replace the original just as long as it is set to the correct mileage...
A speedometer shop/ repair shop can do this for you if you bring the original one in so they can set the mileage .
Old 06-28-2012 | 09:42 PM
EnfuegoZ28's Avatar
If the cluster you are getting has a mechanical odometer then why dont you just roll the mileage up to match the cluster you are taking out?
Old 06-29-2012 | 12:01 AM
esoteric18's Avatar
No clue how you would do that? Any links to write ups
Quick Reply: odometer swap
