Another engine temp related thread & engine hesitation
) the only issue is the engine temp.The problem; the gauge will go from the 180 mark to 210 which i think is normal, to the 3rd peg right before the redline on the temp gauge. At this point i thought maybe i got a bad tstat out of the box (also new) so was going to replace that but someone suggested it wasn't the cause. I also thought air in the system but I have bled it and the heat stays hot now after it warms up. Everything is hooked up correct as far as the hoses go, i don't see how people swap them backwards unless they're completely replacing the system. I also did the TB bypass while i had it all apart but doubt that's related. Forgot the mention the temp will only climb when not moving, if i'm moving or the AC is on it will over cool if anything, according to the gauge going back to 180.
The block was never completely empty of coolant, once the opti & balancer where back on so went the water pump & hoses. From there I added coolant from the water pump. After that the tstat and the rest went back on and i filled from the rap with the top bleeder screw open. I don't know what to do besides RE BLEED, which is getting old, and change out the tstat.
As far as the hesitation once warm and in gear the car will go to 500-600 rpms and almost die out at every stop. The ICM and COIL are new and even had the old ones on there to rule out parts, since I was hoping it was just an icm issue and not the opti when it wouldn't start up. So now i'm thinking possibly the 02 sensor? What else might it be?
If, however, your fans never kick in when stationary with the A/C OFF, then you have an electrical issue (i.e. - relay or fuse or fusable link).
Can you clarify your problem?
At idle, with the A/C on HIGH / Recirc do both fans run at High speed? If they do, then the issue might be one of the coolant temp sensors; I say sensors (plural) as my 96 has two - one for the dash, one for the PCM. Your OBD I 94 may only have one temp sensor - IDK...
No one gave an idea to the stuttering & low idle problem. The car did it before the opti crapped out said the last owner and it has a new icm with thermal grease, coil & opti and still will hesitate at idle. Oxygen sensor maybe? Or dirty maf?
i'll keep the progress updated. I'm hoping my hesitation issues is the exhaust leak coming from the manifold where the air fittings use to be, I have yet to get a solid fix on that. I burnt the crap out of my fingers because for some reason I thought touching it after it was running for a few minutes was smart, felt the leak before my fingers got scorched. All little stuff at this point knock on wood.
Last minute thought, what's the fuse(s) i need to check for the fans? They are coming on with the AC but I don't think while idling without it.
Scan for DTC codes and fix the fan issue.
Christ it seems every thread is regarding this same bullshit
I think the fans turning on late is attributed to either a faulty coolant temp sensor or the oil sensor, or both. My car runs mint but get's 3/4 hot unless going fast w/ air rushing in, and once it's up that hot I get the low RPM miss/die feeling just like you, which I'm pretty sure is the engine pulling timing to protect itself because it's so hot.
Check your fan turn on time and holler back
PS - in my case I think my oil sensor is faulty, occasionally my "low oil" light will come on on the dash when everything is fine so that's why I think it's related to the fan turn on time, as well as the coolant sensor.
1 - They should be turning on sooner regardless.. factory programming is set to have them come on at like 210 or 220 IIRC. I was told a bad coolant temp sensor and/or oil sensor can cause it, but not 100% sure on that one. I know on my car my oil sensor is faulty and sets off the light on the dash even though there is nothing wrong, and I am having the same problem with my fans so it could be related.
2 - Just wire in a manual fan switch, or buy the kit from one of the vendors on the site. They are around 60 bucks last I looked.
3 - Get a tune, a tune is nothing but good for your car anyway. If you don't want to spend the money on a full tune for performance, you can pay just to have the small changes made like the fan turn on temp, speedo recalibration, ect. and it will cost alot less. LT1PCMTUNING (solomon) does it as well as many others.
