Surprise 93 Z28 wont start (wierd huh?)
Old 09-16-2012 | 12:03 AM
98TA6.0's Avatar
Default Surprise 93 Z28 wont start (wierd huh?)
so i picked up a 93 Z28 that had no rail pressure. i replaced the fuel pump this morning and now i have rail pressure. it will burp when i spray starter fluid in but nothing after. i checked the codes and got a 16 (worst code in the universe!!!). the opti was really nasty so i replaced it. still no crank but i no more codes.it will still burp when i spray starter fluid in. i checked voltage at the icm connector and i dont appear to have voltage at A or D but i have power at the ignition fuse. I changed the coil and still no voltage. I wouldnt guess its a spark bc it will burp when starter fluid is sprayed in. Im gonna get a noid set and check for injector pulse but i dont smell fuel in the exhaust so i would assume they arent working. all fuses checked good also. Any input guys?
Old 09-16-2012 | 12:23 AM
98TA6.0's Avatar
so i just double checked with a buddys multimeter. i have 10v at A&D on the ICM harness. does VATS kill the injectors?
Old 09-16-2012 | 12:53 AM
98TA6.0's Avatar
ive got 12 at the injector. im gonna put a noid light on it tomorrow to check for pulse. what are the symptoms of a VATS issue?
Old 09-16-2012 | 01:43 AM
DisasterFormula's Avatar
VATS means it won't turn over at all. Security light stays on when you turn the key to the on position.
Old 09-16-2012 | 01:53 AM
98TA6.0's Avatar
well it turns over and will kinda burp when you crank it. i pulled the opti and turned it by hand to check if the injectors click but nothing. im gonna put a noid light on it tomorrow.
Old 09-16-2012 | 02:26 AM
Did you check voltages on the Opti harness?
Old 09-16-2012 | 02:30 AM
98TA6.0's Avatar
new opti. i would think that if it cranks with starting fluid the opti harness is good.
Old 09-16-2012 | 03:05 AM
Yeah, maybe. What brand is the opti?
Old 09-16-2012 | 05:00 PM
98TA6.0's Avatar
A1cardone from oreillys. ive used one before and its new. i put a noid light on the harness and they pulse. if i spij the opti by hand the injector will click a couple times and then nothing. im thinking the injectors are toast. im soaking them in B12 chemtool now.
Old 09-16-2012 | 06:40 PM
98TA6.0's Avatar
so i soaked them for a couple hours and tested them all twenty or so times with a 9v and they are all good. i put a noid light on the car and they pulse ok but not very strong or anything. i put the light on a little while later and nothing! pcm fried?
Old 09-16-2012 | 07:11 PM
Red33Z28's Avatar
Wiring? Bad ground?
Old 09-16-2012 | 07:18 PM
98TA6.0's Avatar
im looking over all the wiring now. all the grounds seem to be good.
Old 09-16-2012 | 07:22 PM
Red33Z28's Avatar
Maybe it is your injectors?
Old 09-16-2012 | 08:29 PM
Might be a bad connection to the ICM. Try wiggling the pigtail.
Old 09-16-2012 | 08:35 PM
98TA6.0's Avatar
no the injectors are fine. im not getting an injector pulse. i have power to the icm and opti. all my fuses are good and have power. no codes
Old 09-16-2012 | 09:00 PM
98TA6.0's Avatar
its crazy how the symptoms change so quickly. now i am getting 12v at both pins of each injector plug. is this pcm done for? lol.
Old 09-16-2012 | 10:07 PM
Sounds like something somewhere isn't making a good connection. A loose pin or clip, corrosion, etc. Or it could be the opti. Cardone doesn't have the best track record with making optis.
Old 09-16-2012 | 10:20 PM
98TA6.0's Avatar
im getting all the right voltages to the opti and icm.
Old 09-17-2012 | 08:26 PM
defaultexistence's Avatar
I hate to read regurgitated hear-say opinions stated as fact like
As a matter of fact I have over 10,000 miles on my all new Cardone select opti from advance auto parts.. 3,000 of which have been beating on this Brand new 383 H/C motor with out the first hiccup outta the cardone opti.. In a 93
Quick Reply: Surprise 93 Z28 wont start (wierd huh?)
