missing opsu, wtf is this thing? (pics)
Old Nov 2, 2012 | 07:33 PM
KFtransam's Avatar
Default missing opsu, wtf is this thing? (pics)
soo.. i know i probably shouldve looked into this sooner but, since i bought my car in february my oil pressure has always been maxed out..
oil pressure switch right?
i bought a new one and climbed under the car to find...
evidently the previeous owner decided a bolt would work better when he installed the LTs
now im looking for the plug.. and oh.. i think this is it.. wtf is this?
never mind the caked on concrete powder.. hit a construction zone on the way home
but anyway
this thing is rubber around the outside, wrapped in heat resistant tape with
one tan-ish colored wire running to it that (not positive) i think is my opsu wire
and its zip tied to the oil level sensor..
im thinking maybe a dummy to keep from throwing a code? if obd1 even throws a code for that.. idk what to make of this
it has what looks like a plastic button on one end
anyone have any ideas here?
Old Nov 2, 2012 | 07:55 PM
RamAir95TA's Avatar
I'm going to say the bolt is a "plug" for the OPSU and the big rubber thing IS your OPSU.
Curious how the bolt got in there because the threads there are 1/4" NPT (pipe).
If the bolt is holding I would NOT remove it unless you are prepared to chase the threads.
Old Nov 2, 2012 | 07:56 PM
KFtransam's Avatar
better yet, because im unsure and research has lead me nowhere, is this thing even attatched to the opsu wire?
if not, i cant find any loose wireing.. anyone know where it would be hiding?
btw, this is an early 94 for car, so the opsu is positioned over the oil filter as in the 93's
Old Nov 2, 2012 | 07:59 PM
KFtransam's Avatar
my thoughts exactly, now the question is do i rerout to the back of the intake? what do i do with this one wire running to this rubber dealy.. theres no plug or connector.. im a little baffeled here
Old Dec 2, 2012 | 06:16 PM
KFtransam's Avatar
Well I finnally took care of this, turns out you were right, that was my old opsu broken in half and wrapped in protective rubber
I was able to install a 1/4" elbo and a 2" nipple as I've read somewhere on here before
Needless to say, I've got oil pressure!
Hot idle somewhere in the 35-38 range
Old Dec 2, 2012 | 06:34 PM
djjab57's Avatar
If I'm reading all this right I believe what your looking for is inside that insulated tube
Old Dec 2, 2012 | 06:45 PM
KFtransam's Avatar
Yeah I figured that out by simply cutting the rubber jacket off and doing away with it all together.. I just wasn't sure as no research came up with that rubber jacket even being there
All good now though
Old Dec 2, 2012 | 09:05 PM
30696bird's Avatar
Completely warmed up it should not be that high at Idle.
Old Dec 3, 2012 | 12:02 AM
englundjd's Avatar
whats wrong with that pressure? i got a friend with a 96' m6 formy, internally stock, that holds 35-40 psi hot idle
Old Dec 3, 2012 | 09:55 AM
RamAir95TA's Avatar
I don't see a problem with his numbers.
Old Dec 3, 2012 | 02:32 PM
30696bird's Avatar
That's the first time I have seen OP that high at hot idle. The ones I have seen average 20 at idle when hot. Of course I'm not saying having OP that high at idle is a bad thing (although if it stayed 80+ while cruising I would say that would be a concern)
Old Dec 3, 2012 | 04:41 PM
KFtransam's Avatar
More than half throttle and it levels out at about 75.. But yes, completely warm idle is about 35.. Frankly I'm pretty happy with that, kind of leads me to believe there may have been a little work done to the short block.
Could just be wishful thinking but that's some decent pressure for a 160k car
Also, while hooking up my new opsu, I decided I'd check the stamping on the block and trans
Both deffinately begin with "1"
Chevy?
Pontiacs code should begin with 2..
Just strikes up some curiosity
