Re installing heads on 97 SS...
Old Jan 4, 2013 | 09:02 AM
01Z0H6's Avatar
Default Re installing heads on 97 SS...
So i purchased the Fel Pro head gaskets and Bolt kit... Are these gonna be ok? Heads have been off for a month or so.. I have the cylinders taped off as not to let any debris inside. Just purchased car and there is "some" small surface rust inside cylinder walls.. I cleaned, placed a light coat of oil inside and taped when i got the car home. I'll be throwing some new lifters in as well.
Anything i am missing?
Old Jan 4, 2013 | 12:57 PM
Rob94hawk's Avatar
Thread sealer? New intake manifold gaskets? Permatex copper for the seal for the front and rear of the intake manifold to the block.
Old Jan 4, 2013 | 01:34 PM
wrd1972's Avatar
Whats the purpose here? I have never done that.
Old Jan 4, 2013 | 01:46 PM
Rob94hawk's Avatar
True. usually a thin coat of Elmers glue should do.
Old Jan 4, 2013 | 03:28 PM
draggin97s10's Avatar
Sig worthy!
Old Jan 4, 2013 | 05:10 PM
WS Sick's Avatar
Dont forget to torque the bolts properly and in sequence and try to do it all warm.
Lube and seal the bolts the same for conformity. Make sure all surfaces are FLAT and CLEAN!!!!
Old Jan 5, 2013 | 08:23 AM
SS RRR's Avatar
Village Troll
Nice. I was thinking more along the lines of Gorilla Glue.
I've used either Copper or Black and had good luck with both.
Old Jan 5, 2013 | 06:15 PM
NewOrleansLT1's Avatar
I used rubber seals from a Gen1 SBC and a dab of black RTV on the corners..
Old Jan 5, 2013 | 06:58 PM
bufmatmuslepants's Avatar
Go with the 0.026 gaskets and bump that compression a bit while you are in there.
Old Jan 5, 2013 | 08:12 PM
Rob94hawk's Avatar
Speaking of head gaskets do Cometics make 0.26" @ 4.04" bore?
I've only seen either 0.27" @ 4.11" or 0.40" @ 4.04"
