What aftermarket hood clears an LS1 lid swap?
Had the standard VFN Sunoco hood with an LS1 lid. Required little bit of cutting though. Not sure if the wide would be any different, being that I don't think it is actually wider, but just longer/taller (extends to windshield). I could be wrong...
![](http://i16.photobucket.com/albums/b10/greeksnowboarder/WP_000510.jpg)
![](http://i16.photobucket.com/albums/b10/greeksnowboarder/Photo_C942B322-0896-656D-8EFA-91E724E22403.jpg)
It did not need to be cut that much, I kind of went to town on it since I wasn't sure exactly where it was hitting. It turned out to just be one small spot on each side. I don't blame you for not wanting to cut it. I cringed when I did it...
I think it depends on the base and how far you slide the radiator towards the engine, slide it forward and use a stock Z28 lower box and trim it enough i bet you could get away without trimming.
Butch - The VFN sunoco (regular will not fit and will need to be cut 100%. I have one and I had to cut it pretty good. However, without LS1 lid, it fits fine. I also have the SLP lid and I never got it to sit quite right.
I think that harwood that has the wide cowl could fit a lot better. If you can wait a few months, be happy to let you try it all out and bolt it on and see if it works.
