Can someone help... PLEASE
Its a 93z car. M6 with a built LT1, forged internals, cam, full MSD ignition(6al box, opti, coil) I got the car running pretty good. it had a monster exhaust leak when I first got it which I fixed. Now when I've got it out on the highway the car will cut out randomly and when it does it the SES light comes on and off with each cutout the car makes. I can go at WOT and then slow back to speed limit (65ish my speedo isn't working right now) and thats when its the worst. after it does it's deal, the car hits a wall at 3K rpm like it's hitting a rev limiter... IAC valve? Ideas?
however, it does sound like it could be an opti issue.
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Let us know what u find,
cardo
If you have a laptop, you can also get scanning software and a cable from places like TTS Power Systems. I would like to get a setup like that for myself.
I'm no expert on OBDI and OBDII, but it may be getting difficult to find places with OBD1 readers. I know places like Advance Auto and Autozone used to scan cars for free, but I've heard of people having trouble getting OBDI codes pulled.
If you're interested in being able to perform your own scans, which is probably a great idea if you plan to keep the car, do a search on Datamaster or Scanmaster. I guess there are a lot of places that offer scanning software and cables.
Might try that.
Might try that.
Quick cleaning and its been fine ever since.
Not saying it is sounds like Opti issue, I had a MSD fail after a short time. 2nd day I had my car it failed. (Was installed before I bought it forget the miles might of been like 10K)
I would remove it altogether because it adds nothing in terms of performance or value.
