stock manifolds and cat back vs pacesetter lt and dumped?
Ok here's my situation right now I have cc502 with stock manifolds and flowmaster catback. so i just orderd a set of pacesetter lt's with a x-pipe kit from summit and I am wondering what would I gain from changing to this lt dumped system. Hp-tq???
On mine i have got 1.6rr and bolt ons including pacesetter lts with 3in y pipe dumped, i felt big enough difference for me to notice it cars loves higher rpms and sounds anazing im sure ull feel more with ur x setup
If you didn't have the cam I'd say you'd pick up like 15-20whp. But with the cam, ditching stock manifolds and crapmaster.
Honestly man its going to be a whole new car, you'll probably see close to 30whp.
Yea I'm still on 1.5 scorpion rr. From my dyno sheet I'm at 300HP & 325 tq with cam,Cai and stock manifolds and slowmaster. Does that sound about right?
Also should I get it retuned or should I wait until I have 1.6 rockers? And what other bolt ons can can I do. I'm looking to get around 380-400rwhp
if its already tuned for the cam, i'd leave it be, when you go to do roller rockers might as well just do heads to even try and get close to your goal. Like stated unless you plan on spraying its not going to happen with stock heads...
Yea its already tuned for the cam. So my best bet is to call up Lloyd and get his stage one heads with his cam and port my intake while I'm at it and bigger throttle body and rockers??
do the exhaust
dont go bigger then 52mm throttlebody, stock is proabbly fine at this level
do the 1.6's you can use them on new heads later too anyways so might as well
Make sure you have a cold air intake and clean filter
start dropping weight like crazy
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
sounds good just got new filter and now im saving up for rockers and bigger throttle body. its my dd so no weight dropping here lol. thanks for everyone inputs
