K1500 Help
Old Feb 27, 2013 | 07:40 AM
USAFzombie's Avatar
Default K1500 Help
Here's the deal.
I drive a K1500 daily, with a SBC 350 in it (TBI). It currently has Headman Headers, which are wrapped. I do search and recovery K-9 work with this truck, and drive a good hour plus most of the time.
I'm looking to get the best milage I possibly can, while still being able to pull trailers in the 5-7k lbs range. (I don't pull them all the time, just need to retain the ability to)
I'm looking into doing a heads and cam swap, as well as the FAST intake on my 2001 Camaro SS, so I will have the LS6 Intake and Heads/Cam sitting aside.
I also have another SBC 350 in pieces back home in MO. Both of my SBC's are 4 bolt main.
What would be my best route here? A 383 stroker kit, with upgraded intake/TBI, or swapping out to the LS1 heads and cam? Perhaps a Weiand 144/142 supercharger with an intercooler?
-My truck started ticking/knocking last night, and I haven't had time to find out what the problem is yet.
Also, is there any reason why a rotating assembly from an LS1 would not work in the SBC? I'm guessing those parts are the same as any other 350.
Thanks,
-Zombie
Old Feb 27, 2013 | 08:19 AM
93M6Formula's Avatar
Please tell me you are joking....
Not only is this the wrong section, but the only parts interchangable between an LS and a roller SBC are the lifters..... The LS is a completely different engine.
None of what you said makes a bit of sense.
Old Feb 27, 2013 | 08:20 AM
bufmatmuslepants's Avatar
No parts from ls are interchangeable with gen 1 or 2 small blocks. Those tbi 350s have tons of torque and are reliable but performance wise and fuel economy wise they are boat anchors. Either do a complete 5.3 swap or just put in another junkyard long block. A 383 would be stupid because the tbi is basically a 2 barrel carb with only 2 injectors so it not only can't breathe, but it doesn't efficiently distribute fuel to all cylinders.
Old Feb 27, 2013 | 09:09 AM
USAFzombie's Avatar
Thanks for being a useless jerk? At least the other guy explained it. Obviously if I knew that I wouldn't have posted it here, or the question at all. Perhaps I'm on the wrong forums, because every other thread I've read seems to be polite and professional. You just made this forum look like crap to me.
Old Feb 27, 2013 | 09:17 AM
Check out fullsizechevy.com or 67-72chevytrucks.con
USAFzombie's Avatar
Well that sucks. I have been looking at the classifieds on here and found a couple LS1's for sale for a decent price. I may swap out to an LS1 instead. Thoughts on that?
Old Feb 27, 2013 | 09:21 AM
Maybe I came off a little strong but I did explain to you that it won't work.... My bad.
Old Feb 27, 2013 | 09:23 AM
A 4.8, 5.3, or a 6.0 out of a 99+ chevy truck, van etc can be had for cheaper. I would go that route.
Old Feb 27, 2013 | 10:12 AM
Yea aluminum ls1s are overpriced, pick up a complete 5.3 with trans, transfer case, wiring harness and computer for $1000, same price as what you would pay for just an ls1 longblock
Old Feb 27, 2013 | 10:14 AM
USAFzombie's Avatar
What would you expect to be a fair price for an engine like that? I've seen two LS1's on here for under $1500.
Old Feb 27, 2013 | 10:24 AM
Like buffmat said, you can grab any of those 3 engines for $200-$1000 with wiring, computer, sometimes the trans and T-case. It's the way to go for sure.
Old Feb 27, 2013 | 10:47 AM
USAFzombie's Avatar
I had a 2006 Silverado with the 5.3 and hated it. I thought it was complete trash, but it may have just been poor luck. Any ideas where to grab a motor setup like that?
Old Feb 27, 2013 | 10:49 AM
Any local pick n pull or junkyard.
Old Feb 27, 2013 | 12:28 PM
quik95lt1's Avatar
i got a 98 k1500 also.....motor has 189k on it this summer im doing a budget 383 with pro comp heads and a tpi intake for it.....youd be supprised how cheap you can do stuff if you look around.......run of the mill performance parts are everywhere cheap.....flatlanderracing has a scat 9000 crank/i beam rod/hyper speed pro piston kit balanced with rings and bearings for like 950........
Old Feb 27, 2013 | 07:35 PM
USAFzombie's Avatar
Yeah........... Most of that made no sense to me at all.
Old Feb 28, 2013 | 06:15 AM
bowtienut's Avatar
Then you'd best shelve any rebuilding or modding ideas for now.
Old Feb 28, 2013 | 09:03 AM
Back to my original idea, based on your lack of knowledge and experience, I'd just pick up a junkyard tbi short block for $200 and swap that in to fix your knock and do a lot more research for a build.
Quick, he has a tbi you have a vortec mpfi, your motor has potential, his does not.
Old Feb 28, 2013 | 10:46 AM
quik95lt1's Avatar
Im goin backwards lol......the pro comp heads are dirt cheap so im gonna run just a sbc head on it......and the tpi camaro intake will bolt up to it np.......with longggg *** runners and a rpm head room of about 4500 its great........biggggg torque down low espically with the bumpstick i wanna run.....building a gas powered diesel lol
Old Feb 28, 2013 | 02:01 PM
FWIW I have a tbi 350 in my 2 door Tahoe, 3.73 gears 33s, throttle body spacer, big k&n filter, and no muffler in a 3" catback and it tows great. I had my car and a lot of tools and parts on a 2300lb uhaul trailer, so 6000lbs about and towed that 2 hours to Cecil and back no issue. Just put it in 3 so you don't burn up the trans in OD and it will hold 65 on the highway at around 3000 rpm all day long getting 9-10mpg. Before me when it was stock (still with 3.73s) my dad towed his 5000lb boat 14 hours each way to NC from ct in 100 degree heat every summer for 10 years and never had a problem. 150k on original engine and trans with synthetic fluids changed religiously. I had a 95 with 3.42s and 33s and the gear difference felt huge, towing the same boat it was not as happy.
Old Feb 28, 2013 | 02:28 PM
quik95lt1's Avatar
yea mine tows well i can pull the car and trailer and run 75-80 all day in OD at about 2100 rpm.......motors just got a lot of miles on it now, im getting cam pos codes cause the TC is stretched out and i got a lifter tick now....gonna just build somehting cheap new and torqy for it
