what cam is right for me
That is a rediculously low compression for an N/A LT1. If that's truly what it is I would be pulling that motor apart and redoing it cuz obviously nothing was planned right for that motor unless it was meant for boost. Probably has a junk cast crank in it too..
I believe too big of a lift cam with a turbo or any type of forced induction would require a ton of boost retard, and probably just all around useless.
heres the deal.......8.5:1 is very low, if you are going to run FI then its on the low end of acceptable, as for the lifter issue id be careful if there was any debris (metal) that went through the motor form that problem.......also before just slamming boost at it what were the rings gapped at? whats in it for pistons and rods? theres alot of ?'s to be answered.........as for running a bigger cam, more lift will have 0 to do with the amount of timing reduction the motor woudl have to have due to boost pressure so thats just downright wrong..........whats on the motor for heads also that will dictate your cam choice as well as gear ratio stall size and intended usage.....
